Manifold Stud & Helicoil Size
Posted: Wed May 07, 2008 9:24 am
by sdemmery
Hi Guys & Girls
I know this has been done to death, but I need to helicoil Manifold Stud No1. Have had the Squeel for several months nows. Its driving me nuts! :evil:
Ive already tried extracting, retapping, but no luck. So Im about to helicoil but am unsure of what helicoil kit to buy. Im refitting a standard stud back, I think the stud is 6mm? is that right? & I need a 8mm hole for the helicoil? So is a "Helicoil thread repair kit M8 x 1.25" what I need? I take it the pitch is the 1.25. Is that the pitch we have on those studs? The M8 does that refer to the internal diameter of the coil? if so should I have an M6. I assumed the 6 or 8 on the M is the size in mm.
I did a forum search, but couldn't find any specifics on helicoil sizes, so if anyone does know It would be a great help.
Stu
Re: Manifold Stud & Helicoil Size
Posted: Wed May 07, 2008 11:01 am
by Dolly1
Hi,why complicate the issue.Drill 6.75 n tap 8mm.
Posted: Wed May 07, 2008 12:02 pm
by sdemmery
Thanks for the quick response.
I have already tried to drill out & retap to the original size, but but luck. Are you suggesting using a larger 8mm stud (are the originals 6mm?) If so I guess thats a good option. Ive heard that a helicoiled thread is much tougher than a thread straight into the ally head this was also a considration for helicoiling for me. I dont want to have to do this job again :cry:
It also seems that most posters here with this issue tend to helicoil, I'm all up for doing it different though as long as it works :wink:
Someone must know!
Posted: Tue May 20, 2008 8:46 pm
by sdemmery
Hi Guys
Well its official I really need to fit a Helicoil to fix Stud No1 problem. I did ask this before but had no response. Maybe I need to say it louder :?:
:lol: WHAT HELICOIL SIZE DO I NEED? :lol:
Ive read here that someone thought it was M8 but that seems a bit big. Stud only looks like 6 to 7mm in diameter to me. As I said surely someone must know, you are all so knowledgeable in all things bongo :mrgreen:
Stu
Posted: Tue May 20, 2008 11:07 pm
by dandywarhol
The original stud is 8mm
Posted: Tue May 20, 2008 11:34 pm
by The Great Pretender
Not wanting to hijack this thread but it has got me wondering why number one stud snaps, any idears peeps?
Posted: Wed May 21, 2008 6:47 pm
by sdemmery
Thanks Dandy, I have Standard Studs so 8mm it is then. Helicoil Kit on order :)
I guess that Stud no 1 breaks as this is the furthest point from what is in effect the fulcrum of a lever. The Exhaust I suppose is acting as this lever in a way :?: :?: :?: Well that was my first thought but Im probably wrong
Thanks again Dandy
Stu
Re: Manifold Stud & Helicoil Size - Update!
Posted: Tue May 27, 2008 3:52 pm
by sdemmery
Just thought I would keep you all updated.
Helicoil Kit arrived & job is now a good Un! no screechy screechy. Wahoooo. Wish I had done this properly 6 months ago. Mind you I'm dab hand at taking the altenator off now :) It is true those helicoils are far stronger than the original thread.
Also managed to fit new front drop links while I was about, now the rear ones, thats a whole new topic, but needless to say the nuts are stuck firm & I mean firm, ring spanner breakingly firm in fact :evil:
Thanks Everyone for you advice. Question is should I keep the helicoil kit or sell it on? Only cost me £30 & I just know if I sell it I will need it again, best keep it in the garage. But if any of you Bristol guys need a lend you know where to come.
Stu
Posted: Tue May 27, 2008 7:53 pm
by bongomaan
no1 stud gone on me,but did your auto box misbehave with stud squealing ? perhaps i have another issue ! (not another !) cheers....
Posted: Tue May 27, 2008 8:20 pm
by sdemmery
Hi bongomaan,
I dont want to shout too loudly as wongo bongo is just behind me on the drive & she may hear me. But no I didnt have any auto box problems. I can't really see how the two could be related. Stud No1 going just caused the exhaust manifold not to seat correctly resulting in a squeel of air escaping.
Oil levels are ok in the auto box are they? Worth a check or even a change I guess.
Good Luck with it
Stu
Posted: Tue May 27, 2008 8:47 pm
by bongomaan
hi stu, thanks for the reply,the stud snapped because i replaced back box and middle section,when i tried it out there it was busteded,i replaced the exhaust because the old one was blocked and she broke down ,just before she went the gear box was hunting i was hoping the two were related but it looks like her issue again !!! but in reply atf fluid red halfway up the stick and no smell of toast !!!!
