Lengthways Roofbars
Posted: Sat May 03, 2008 7:31 pm
by Willy Eckerslike
I've done a search on the previous posts about roofbars and most seem to talk about crossways bars (as you'd expect). I'd like to fit some lengthways bars permanently to my AFT fitting points with the aim of swapping my crossbars that I use on my Berlingo, as and when required.
Has anyone succesfully fitted lengthways bars like this? If so what did you use? I was thinking of seeing what I could get from a scrap dealer off an old estate car and do some kind of fit.
Andy
Re: Lengthways Roofbars
Posted: Sat May 03, 2008 8:36 pm
by Ian
Posted: Sun May 04, 2008 1:40 pm
by Willy Eckerslike
Yeh, something like that; knew I'd seen some somewhere but couldn't remeber where?!
Do you know if the Thule 755 footpack will fit on those bars?
Andy
Posted: Sun May 04, 2008 5:27 pm
by Ian
You don't need footpacks. They screw straight in to the free top.
Posted: Mon May 05, 2008 10:54 am
by Willy Eckerslike
I'm looking for lengthways rails to stay on the AFT permanently so the ones you pointed me to look ideal but the other important factor is that I can transfer my Thule Crossbars from my Berlingo to the Bongo. The Thules use the 755 footpack.
With your roofrails being cylindrical I'm not sure they will work. Does anybody else have experience of using the 755 footpack with these rails?
Andy
Posted: Wed May 07, 2008 12:21 pm
by axeltramp
if the 755 footbars were used on normal roof rails they should fit ok i used the thule ones that i had on my vectra estate with ian's lengthways bars no problem.
