Coil Light
Posted: Sat Apr 26, 2008 10:20 am
by neeb
Hi All
Just purchased a new bongo and the orange coil light keeps flashing?? Any ideas?
Neil and Gina
Re: Coil Light
Posted: Sat Apr 26, 2008 10:22 am
by westonwarrior
Im sure some one will come up with an answer soon
but in the mean time put your location in your profile as sometimes a local can take a look for you.
Was it a private sale?
Re: Coil Light
Posted: Sat Apr 26, 2008 10:28 am
by neeb
HI
Thanks for the reply. Not private bought it from a garage on Newport Road.
Neil and Gina
Re: Coil Light
Posted: Sat Apr 26, 2008 10:29 am
by westonwarrior
Newport road Cardiff??
I would take it back to them to sort it as it should be covered by any warrenty
Re: Coil Light
Posted: Sat Apr 26, 2008 10:41 am
by scanner
Just checked in the handbook and it says it is also the "Scavenging Fan Warning light"
That is the big fan just in front of the engine, I think.
Re: Coil Light
Posted: Sat Apr 26, 2008 11:10 am
by neeb
Scavenger fan warning light??? help
Neil and Gina
Re: Coil Light
Posted: Sat Apr 26, 2008 12:43 pm
by Rhod
This problem came up recently - you might find the answer in this thread
http://www.igmaynard.co.uk/bongo/forum/ ... ng#p185435
Or try putting "flashing AND scavenger" into Search for some more suggestions.
Would agree that it's the dealers problem to sort though.
Good luck
Rhod
Re: Coil Light
Posted: Mon Apr 28, 2008 7:17 pm
by zimmer
I don't know if this will help you. My bongo had a similar problem, the glow plug light would come on for 3 or 4 seconds after the engine had fired up, It then went out and there was no more problem until the next time I started the engine. It has done this for the 3 years I have owned it. I recently fitted a new heavy duty battery and the fault has never re-occurred. I don't understand why this has fixed it, maybe a slight fault on the earth or a low voltage. It never affected the running, starting etc. Good luck anyway.
Richard
