Broken anti roll bar bracket no 2
Post by missfixit70 » Wed Apr 23, 2008 10:57 pm
Noticed yesterday that speed bumps had got noisier again & the handling felt distinctly iffy, when I checked, my suspicions were proved correct, the second of my original anti roll bar brackets had snapped :roll: . The first one went a couple of months ago, replaced it with a homemade one as mot was next day, ordered a new pair, but hadn't got around to fitting them. So half an hour later job done :D The homemade one was still doing fine, will hang on to it as an emergency spare :wink:
Re: Broken anti roll bar bracket no 2
Post by mikeonb4c » Wed Apr 23, 2008 11:50 pm
good. not a lot more I can say :lol: :lol: :lol:
Post by Bob » Wed Apr 23, 2008 11:54 pm
Not called Missfixit for nothing, well doene Kirsty. :D
The Great Pretender
Post by The Great Pretender » Thu Apr 24, 2008 12:04 am
missfixit70 wrote:Noticed yesterday that speed bumps had got noisier again & the handling felt distinctly iffy, when I checked, my suspicions were proved correct, the second of my original anti roll bar brackets had snapped :roll: . The first one went a couple of months ago, replaced it with a homemade one as mot was next day, ordered a new pair, but hadn't got around to fitting them. So half an hour later job done :D The homemade one was still doing fine, will hang on to it as an emergency spare :wink:
Tut tut, make another and keep or sell on fleebay the inferior ones. =D>
To infinity and beyond
Post by missfixit70 » Thu Apr 24, 2008 12:12 am
Don't think I'd have trusted the homemade one long term , I'm sure the new ones will last at least another 12 years :D they definitely don't look inferior to our bent piece of scrap metal, but it did it's job :wink:
The Great Pretender
Post by The Great Pretender » Thu Apr 24, 2008 12:25 am
missfixit70 wrote:Don't think I'd have trusted the homemade one long term , I'm sure the new ones will last at least another 12 years :D they definitely don't look inferior to our bent piece of scrap metal, but it did it's job :wink:
And as Fred Dibnah used to bend metal as they did in the industrial revolution, whats wrong with that? :lol: :roll: :wink:
Post by bigdaddycain » Thu Apr 24, 2008 1:41 am
Well done for sorting it kirsty.... :wink:
Fred dibnah is (was?) an inspiration to me, R.I.P. fred.... :(
WISHIHADABONGO
Post by WISHIHADABONGO » Thu Apr 24, 2008 9:46 am
Do you have to have the van on a ramp to change the bracket and bush, I have ordered a pair of bushes and brackets for mine and wondered how easy it was to do and what tools are required :wink:
Post by missfixit70 » Thu Apr 24, 2008 11:07 am
Just put mine on drive on ramps on the drive, wd40 or similar to pre soak your nuts a few hours before, 19mm socket I think, that should be it, You may need some fine emery if your bar has any corrosion, mine was ok. I had to use a g clamp to help pull the bar back into position on the broken one where it had dropped a bit. Other than that dead simple :D
WISHIHADABONGO
Post by WISHIHADABONGO » Thu Apr 24, 2008 1:50 pm
sounds easy enough mite try squeezing under the Bongo this eve.... :mrgreen:
WISHIHADABONGO
Post by WISHIHADABONGO » Thu Apr 24, 2008 1:56 pm
Anyone know if the bushes are the same on any other mazda?
cheffy34
Post by cheffy34 » Sat Apr 26, 2008 3:25 am
My bracket went today aswell, uncanny :!: just after i bought the rear pads :roll:
Post by missfixit70 » Mon Apr 28, 2008 1:13 am
I'd change them all then while you're at it Cheffy, you'll only be under there again in a few weeks/months if you don't :roll:
cheffy34
Post by cheffy34 » Mon Apr 28, 2008 11:37 am
missfixit70 wrote:I'd change them all then while you're at it Cheffy, you'll only be under there again in a few weeks/months if you don't :roll:
Yeh order both MSF i thought the exact same when i read your second gave up the ghost, new bushes aswell :D :roll:
