Immobilizer alarm.. (an on going saga).
jaylee
Post by jaylee » Wed Apr 16, 2008 8:56 am
I'm a bit of an Indiana Jones when it comes to auto electrics.. So far no fuses blown yet!
I need to find the ignition wire to tap in to (the one that's live in position two), what colours that?
I have another wire that needs to go to the door switch courtesy light, can i run it from fuse one?
& where do i find the starter solenoid terminal, is it anywhere under a seat per chance??
Cheers! :D
You've Been Bongod
Re: Immobilizer alarm.. (an on going saga).
Post by You've Been Bongod » Wed Apr 16, 2008 5:44 pm
jaylee pm roosteruk he will know
you've been bongod
dreamwarrioruk
Post by dreamwarrioruk » Wed Apr 16, 2008 6:27 pm
on my 1995 bongo the switched ignition wire is blue.
why not run direct to one of the door pins, easy to gain access to.
not sure on solenoid but if you lift up the drivers seat there is a white multiplug, if you unplug that then the bongo wont start but i think thats a fuel cut off.
talking rubbish now so ignore the last one and pm carl, he will probably be able to help with that one.
mike, jo and emma
cheffy34
Post by cheffy34 » Wed Apr 16, 2008 6:47 pm
jaylee wrote:Hi,
Cheers! :D
acc live red/black trace, starter yellow, perm live blue or blue/white trace only the blue stays live while crannking engine over you need that one, take fuel pump behind fuse 9, be carefull tho mine v6 petrol im sure the wires are diff colours, take the trips to the pin switches it easier.You may need diods tho your decision :wink:
