Page 1 of 2
Anyone seen a nut like this!
Posted: Tue Apr 15, 2008 9:44 pm
by Slybacon
Please help. I'm trying to remove this nut from the end of the fuel pump - I've tried every socket I can - but the 3 flat sides are causing a real headache - A 1" almost fits, a 26mm is too big. Ahrgggg!
I reckon I need a specialist tool but despite all my hunting around I can't find any info.
Help, help!
Re: Anyone seen a nut like this!
Posted: Tue Apr 15, 2008 9:56 pm
by francophile1947
Posted: Tue Apr 15, 2008 10:02 pm
by Slybacon
Thanks John.
Worth a try if I can't find the exact one for the job.
I'm still hoping that some professional mechanic may have an idea??
Andrew
Posted: Tue Apr 15, 2008 10:07 pm
by lizard
These are quite good for the above odd size nuts.
Posted: Tue Apr 15, 2008 11:55 pm
Try PMing Dandywarhol as he is top dog with mechanicals (lectures on it at the local college)
Posted: Tue Apr 15, 2008 11:58 pm
by dandywarhol
It's a special tool job sly - to stop people tinkering..................
I like franco's idea though cos it won't be all that tight.
Posted: Wed Apr 16, 2008 9:27 am
by Slybacon
Found the tool I need. Only problem is supplier is in China!!
I've got 3 things to try:
1. The 1" socket almost fits - so I am going to try and heat it a little and see if I can get it on.
2. Get one of those cheapo sockets suggested by Franco
3. Get some chemical metal and try and mould a tool inside a larger socket(!)
4. Speak nicely to a kind, hardworking garage and see if they'll let me borrow/hire a socket.
The joys of motoring!
Andrew
Posted: Wed Apr 16, 2008 9:54 am
by fred
If all else fails and access permits - you could try grinding the round sides flat(ish) or better still use a plumbers basin wrench -
http://www.samstagsales.com/vbw/images/vbw149005x.jpg
Posted: Wed Apr 16, 2008 11:23 am
by helen&tony
I like the thinking, Fred....another technique my father taught me was to drill a small hole near the edge , and drift the thing round with a centre-punch, keeping the centre-pop at a tangent all the way as you hit it
Posted: Wed Apr 16, 2008 11:35 am
by scanner
If you can get access a Stilson wrench will turn it or a pair of the curved jaw Molegrips.
Posted: Wed Apr 16, 2008 1:41 pm
Tee hee. I'm sorry - just stopped giggling at this one. Whatever you do dude, DON'T WRECK IT as the cost of a new diesel injector could make your eyes water. But seriously - good luck
Posted: Wed Apr 16, 2008 5:42 pm
by You've Been Bongod
francophile1947 you will find that was called a gator grip
and they were good
you've been bongod
Posted: Wed Apr 16, 2008 8:02 pm
by francophile1947
and they were good
you've been bongod
No idea what it was called, but it only cost about a quid and has been worth much more than that. I really didn't think it would work but it worked a treat on anything except really small nuts/bolts - just wish I knew where it was now
Posted: Wed Apr 16, 2008 8:10 pm
by maxheadroom
Posted: Wed Apr 16, 2008 8:11 pm
by francophile1947
That's it
