Page 1 of 2
sender unit
Posted: Sun Apr 13, 2008 9:00 pm
by steady1946
Can anyone tell me where exactly is the sender unit for the temperature gauge.
Re: sender unit
Posted: Sun Apr 13, 2008 9:48 pm
by maxheadroom
steady1946
Right hand side of the engine, under drivers seat. front of the head, brass thingy with 1 wire coming out of it.
Hope this helps, I have seen a picture on the forum some where
Re: sender unit
Posted: Sun Apr 13, 2008 10:33 pm
by susan
Just had my glow plugs replaced and now found out that my temperature gauge is not working.Could anyone tell me what i need to do or get
Re: sender unit
Posted: Sun Apr 13, 2008 10:38 pm
by maxheadroom
Re: sender unit
Posted: Sun Apr 13, 2008 10:39 pm
by missfixit70
Sounds like whoever did the plugs has damaged the sender or wire, I'd take it back & get them to sort it for free. You should be able to see if its damaged, thanks to maxheadroom finding the piccy.
Re: sender unit
Posted: Sun Apr 13, 2008 10:57 pm
by susan
Many thanks just the thing i needed,would it have the green wire like i can see in the picture coming out of it? I am ringing the garage tomorow anyway,been very pleased so far with them for the last 3yrs,but this time the young chap tried to take off my centre hubcaps and sheered off the screw heads not one but two
,so had to get them drilled out,and had him check my break pads, had bought new ones for him to replace,but he said that they were fine no need to put new on yet,but on a trip up the motorway yesterday the van was shuddering on 60 then wasent to bad on 65-70, im hoping im right on thinking that this may be due to the balancing of the wheels
Re: sender unit
Posted: Sun Apr 13, 2008 11:05 pm
by missfixit70
Get the wheels balanced & tracking checked ( between -1 and 7 mm toe in), should sort the shuddering - it's fairly normal, nowt to worry about hopefully. The sender should have a wire connected to feed the temp gauge, may just need connecting back on if it got knocked or taken off while doing the plugs. Would recommend geting a Mason temp alarm fitted, it actually makes the temp gauge work & move with temp rather than just sitting at 11 o clock, & has a settable alarm, less than £30 & dead easy to fit.
Re: sender unit
Posted: Sun Apr 13, 2008 11:18 pm
by The Great Pretender
missfixit70 wrote:Get the wheels balanced & tracking checked ( between -1 and 7 mm toe in), should sort the shuddering - it's fairly normal, nowt to worry about hopefully. The sender should have a wire connected to feed the temp gauge, may just need connecting back on if it got knocked or taken off while doing the plugs. Would recommend geting a Mason temp alarm fitted, it actually makes the temp gauge work & move with temp rather than just sitting at 11 o clock, & has a settable alarm, less than £30 & dead easy to fit.
7mm toe in?
Thats a lot of toe, wont that scrub the tyres?
Re: sender unit
Posted: Sun Apr 13, 2008 11:26 pm
by dandywarhol
That's what the clever lil' peeps in Japan say.............................
Re: sender unit
Posted: Sun Apr 13, 2008 11:31 pm
dandywarhol wrote:That's what the clever lil' peps in Japan say.............................
But they dont drive anywhere.
Re: sender unit
Posted: Sun Apr 13, 2008 11:38 pm
by dandywarhol
So , what ya gonna do TGP - rewrite the whole manual
Re: sender unit
Posted: Sun Apr 13, 2008 11:57 pm
by steady1946
Cheers Maxheadroom.Had a look today but couldn't find it .Now you have shown me where it is perhaps I can rectify my temerature gauge not working!
Re: sender unit
Posted: Mon Apr 14, 2008 12:01 am
dandywarhol wrote:So , what ya gonna do TGP - rewrite the whole manual
Nope just use the knowledge that I have.
If I was using 1/4in toe in on a race car it would mean that there was a problem with ackermann.
Remember him?
On a road car dont you think 1/4in toe in will cause tyre wear?
Re: sender unit
Posted: Mon Apr 14, 2008 12:18 am
by dandywarhol
I set mine midway at 3mm but there's so much yield on the suspension rubber bushes and sidewalls on these Bongos I doubt 6mm would make much difference than 3mm.
Re: sender unit
Posted: Mon Apr 14, 2008 12:34 am
dandywarhol wrote:I set mine midway at 3mm but there's so much yield on the suspension rubber bushes and sidewalls on these Bongos I doubt 6mm would make much difference than 3mm.
At the speed we drive at around town I dont think 'yield' is a problem. Sidewalls of the tyres are different and normally the taller the sidewall the greater the slip angle.
