Taking cylinder head off for inspection - any tips?
Posted: Wed Apr 02, 2008 1:29 pm
I'm having problems with excess pressure in the coolant system at the moment. Despite bleeding as per the various methods, the problem still occurs, so I plan is to take the head off for a closer look. I will be using the info in the manual & relevant factsheets in the members section. Here's my list of items to get/change whilst doing this. Is there anything else you recommend & any pitfalls to be wary of?
* Headgasket set inc: Head Gasket, Rocker Cover Gasket, Cam Shaft Seals, Rocker Cover Seals, Valve Stem Seals & Manifold gaskets (inlet and exhaust). I won't bother changing valve stem seals
* Cambelt
* Cambelt tensioner spring
* Cambelt tensioner - is this necessary? It has supposedly been replaced before - do they wear out?
* Head bolts
* Thermostat
* Replace hoses with Flippa's silicon pipes
That little lot comes to a tad under £300 from the club shop, Flippa & Bongobits. Items that I might change:
* Water pump - if the impeller, bearings & seals are ok - is it worth it? What's the typical lifespan?
* Radiator - there are no leaks or obvious hotspots. The water goes in red hot & comes out practically cold. I'll give it another good flush, but I don't believe it will be contributing to current problems. Does anyone know the exact fluid capacity of the rad? I was going to measure how much liquid it holds which would tell me if the capacity was reduced by silt & gunge.
Any advice & comments welcomed. Thanks
* Cambelt
* Head bolts
* Thermostat
