Passenger window not working
Posted: Tue Mar 25, 2008 12:49 pm
by Majorbloodnock
Sorry for the repeater, but I have spent the best part of an hour in the obscurity of the search facility and got sick of opening totally non-related topics.
Anyway, my passenger window will not operate on either door switches and I wondered if you good people (and the bad ones among you) had any ideas on where to start fault finding?
Any help is appreciated
Stu
Posted: Tue Mar 25, 2008 1:33 pm
I think a common reason give on here is that the wiring loom, where it passes from bodywork to door, is prone to fatiguing and fracturing of wires due to repeating flexing. I imagine this could explain both switches not working. I guess I have to expect this problem too at some point and/or take preventative measures. no doubt those that had had to deal with it will come back with more detailed advice on identifying and fixing the problem.
Good luck!
Posted: Tue Mar 25, 2008 2:03 pm
by Harry
Sorry if this sounds a bit obvious but have you flicked the little switch by the drivers side window buttons...as this switches the passenger side windows on or off?
good luck
H :oops:
Posted: Tue Mar 25, 2008 2:31 pm
by andyh
Just fixed mine.. it was the drivers door switch - it gets a supply or earth from there - took it apart (with care!!) and the contacts were all green and cruddy. Quick clean and all good....
Posted: Tue Mar 25, 2008 3:46 pm
by daveblueozzie
It also does no harm to spray silicon/grease into the window runners to keep them smooth and then it does not strain the motors.
Posted: Tue Mar 25, 2008 5:01 pm
by Majorbloodnock
Harry wrote:Sorry if this sounds a bit obvious but have you flicked the little switch by the drivers side window buttons...as this switches the passenger side windows on or off?
good luck
H :oops:
#-o :oops: :oops: :oops: Thanks Harry :roll:
Posted: Tue Mar 25, 2008 5:44 pm
by Harry
He he...accidently knocked the switch myself at the weekend... followed by brief panic then forehead slapping solved it :oops:
Posted: Tue Mar 25, 2008 7:35 pm
by westonwarrior
the simple solutions are usualy the ones that are overlooked we all do it :lol:
Glad it got sorted cheaply
Posted: Wed Mar 26, 2008 12:25 am
by bigdaddycain
That's a favourite bongo :oops: problem stu..... The other being roof not opening/closing, posting a query on here, then realizing that the handbrake is off... :wink:
Posted: Wed Mar 26, 2008 8:19 pm
by Majorbloodnock
bigdaddycain wrote:That's a favourite bongo :oops: problem stu..... The other being roof not opening/closing, posting a query on here, then realizing that the handbrake is off... :wink:
I know, I'm an idot....but I'm a relieved idiot! :lol:
It's just the assumptions that we Bongo owners make due to the stories of doom you read - If I ever need to top up with water, I will be convinced that my head is cracked :roll:
Posted: Wed Mar 26, 2008 8:36 pm
by missfixit70
S'alright, mine wouldn't start at all today after I dropped mum & her shopping off, turned the key - nada. didn't take long to realise I'd not put it in P :oops: , still had that panic for a couple of seconds though :roll:
