A Big Hello and sorry to say I have to start with a problem
Posted: Mon Mar 24, 2008 6:33 pm
Firstly I would like to say a big hello from me and my wife, Sharon from sunny Birmingham. We have not had our bongo long, about 3 weeks in all. It's took this time to pluck up the courage to post a message ( i'm a bit shy
Me and my wife first started looking for a bongo last year but only concerntrated on the camper versions. Soon realised this wasn,t the best option for us as it had to be used to ferry all the kids around on a day to day basis but we still felt that we could achieve cheap holidays and a daily run about in one vehicle and the bongo fitted the bill.
My wife only had one stipulation and it was she wanted the aqua marine colour, this has proved very difficult but finally found one. It is the 2.5 td auto with 4wd. It seemed to be in good order, very clean and looked after but we have a problem.
We were due to go away this bank holiday for the first time and were itching to try it out,but unfotunately we had an alternator problem last week. I took the altenator to our local garage that re-conditions them, and they quickly turned it around. Once I got it home I started to install it, I noticed that when the connector had been inserted along with the battery connection, it started to make a noise and then smoke
, I immediately disconnected the alternator and took it back to the garage for him to check it out.
The reason I am posting this message is to make sure the connections are correct and I am getting what I should get at the plug end for the alternator
There are two wires in a connector that plugs into the alternator and the main charge lead to the battery. There is a thin blue/yellow wire which I gather is from the charge light on the dash and I have checked this and it seems ok but there is a thick brown wire in the connector that is perminant 12v, I would just like to confirm that this is correct and to make sure its not supposed to be ign 12v.
I am due to pick up the alternator again tomorow and would just like to make sure all is ok with the car side of things before the garage says it is my fault
Sorry for waffle I am new to forums.
Cheers Lee
Cheers Lee
