hold light flashing and no speedo
Posted: Sat Mar 22, 2008 5:39 pm
by kernowbongo
Whilst driving the Bongo today, the hold light started to flash, and the speedo stopped working. I presume the two things are connected rather than coincidence. It only happened once, the next time i turned it off and on again there were no problems. Can anyone shed any light on what the problem might be ?
Posted: Sat Mar 22, 2008 6:32 pm
by vanvliet
Sounds like a loose connection on the back of the speedo .If it happens again a firm tap can fix it when on the move! You can then do the job properly when you get home . A fifteen minute task job to remove , tighten ( careful now!) and refit
Posted: Sat Mar 22, 2008 6:33 pm
by francophile1947
Have you got a replacement dial on your speedo or a chip (it's chipped if the odometer reads in miles) - I believe this is a common problem with the speedo converter chip. There's loads of posts on here regarding this.
Posted: Sat Mar 22, 2008 6:42 pm
by vanvliet
same thing can happen if you have had an MPH speedo fitted and the connectoions are loose - - -
Posted: Sat Mar 22, 2008 7:29 pm
by kernowbongo
Thanks for your repies, whats the best way to get at the back of the speedo to check the connections ?
Posted: Sat Mar 22, 2008 7:44 pm
by missfixit70
Drop the steering wheel to its lowest adjustment, undo the 4 screws around the fascia, lift it out, 4 more screws holding the clocks in, pull it out, dead easy :wink:
Posted: Sat Mar 22, 2008 7:50 pm
by kernowbongo
thanks for the info. thats my job for tomorrow sorted out then !! :D :D
speedo and hold light
Posted: Sat Mar 22, 2008 9:23 pm
by motorwizard
(I think the others are pointing you in the right direction The gearbox takes a signal off the speedo circuit board. There is a screw marked speedo which connects circuit board to the wire to the gearbox. When I got my Freda the hold light was flashing it was eventually traced to the printed circuit. In Japan they had connected the gearbox to a GPS which didnt work in the UK and removed the screw.
In your case it could be the input from the gearbox since the speedo and hold are faulty. The input signal comes from the sender at the back of the gear box check that is secure it is easy to check. Hope you solve it
Posted: Sun Mar 30, 2008 9:06 pm
by jonboy
This happened to me then the alternator packed in
Posted: Sun Mar 30, 2008 9:24 pm
by Jake
This happened to me when i had lots of gadgets plugged in!!
Jake
Posted: Sun Mar 30, 2008 11:15 pm
by bigdaddycain
Jake wrote:This happened to me when i had lots of gadgets plugged in!!
Jake
In the rear ciggy socket, yes?
Posted: Mon Mar 31, 2008 10:36 pm
by Happy Shopper
This has happened to me a few times. I just pull over switch it off and switch it on again (and I don't work in IT) and it's been fine. It's usually happened when it's been cold / been standing a while / been driven a short distance, turned off and then started again after a short stop (paper shop). As far as I know it's to do with the speedo chip fitted to convert km to miles. There has been no ill effects and it's so rare I just put up with it.
Re: hold light flashing and no speedo
Posted: Wed Apr 02, 2008 8:04 pm
by Jake
Yes was the ciggy lighter. had no problems sinse though.
Jake
Posted: Fri Apr 04, 2008 2:05 am
by bournemouthken
I had the same on my Freda, it turned out that where the speedo had been chipped, the wires were just twisted togeather instead of being soldered thus it was a bad connection.
