water water water
- Apprentice Bongonaut
water water water
hi all, had my rear heater pipes joined together as i had a leak in the rear heater. were by passed because mechanic thought rear matrix had gone, all ok for 2 weeks. Help! water soaked through drivers carpet now. another trip to garage who said it could be front matrix now!!!! Any ideas?
I don't wanna P**s on your parade but to blow matrix's requires excess pressure normally associated with a blown head gasket and the drivers inane ability to soldier on regardless of the resultant damage!
My wife told me of water coming into the front passenger footwell with a 'Funny smell' in her Renault..... two weeks after it started
You guess the rest.................
Matrix blown, headgasket blown ........
So depressing to think of the cause
I hope Im wrong!
I traded the Renault in as to completly remove the dash on an old car was a non starter.
I hope Im wrong!
Live long die oblong
- You've Been Bongod
water water water
hi popthebrick i had a rear heater matrix fitted cost was about £180 ish i think just for the matrix
you can get a second hand one for about £40 ish or take yours to a tester and get it checked for pressure first
you've been bongod
you've been bongod
I'm no expert on the bongo's cooling system, but it could be that the heater matrix is simply ready for replacing, they get blocked so easily and they are very delicate. Is there an option to obtain a reconditioned one if it is? However, it could be a sign of something more serious
If it was me I'd be asking the garage to do a block/pressure test for some help finding out if it's a head gasket problem, my local garage charged £20 for my mazda. To state what is probably the obvious too, new hoses are always an idea if you've had them for a while.
I hope you get it sorted.
