Dash electrics...rear lights/rear fog
Posted: Tue Feb 19, 2008 1:35 pm
I need to invstigate a "sparking" sound coming from my dash. I was hoping it was some loose trim, bit I suspect a loose wire. I haven't had a good look yet (at work) but noticed this AM that rear fogs weren't working, nor were rear lights but rear brake lights were. Head lights all ok. All other electrics seem fine. I'm hoping its to do with the (aftermarket, uk fitted) rear fog switch.
Am I right that the switch will have three connections....one to earth, one to live and one to the light switch so as fogs only come on when lights are on?
Is it easy enough to take the dash apart for easy access to the switches and wires?
Any guess from these symptons as to where my loose connection might be?
Any other thoughts / observations would bemost welcome.
