Glowplugs - are these better ?
Posted: Mon Feb 18, 2008 11:22 pm
by kawasaki kid
Need some new glowplugs - one failing and van shaking to bits on first startup of the day.
Fitted this set about 14 months ago so don`t want to do it again in another 14 months - Found these on Ebay and was wondering if anyone has them fitted - Genesis Twin Coil Glowplugs - they are sold as an upgrade and are supposed to be better than standard plugs - Item # 120217310630. They are sold by someone I have bought off before with no problems. Thanks in advance for any replys. Ian.
Posted: Mon Feb 18, 2008 11:32 pm
by ford tinny
Hello,
I bought these glow plugs about 4/5 months ago. No problems ____
apart from these plugs where shorter than the one's i took out, meaning that the glow plug track would not fit, So instead of returning them i fitted them, put the little nuts on, then fitted the glow plug track and used the old little nuts to secure the track. Works fine. Hope this helps!!
Posted: Thu Mar 27, 2008 9:51 pm
by grahamlw1946
Hello
After getting through 2 sets of glowplugs in 2 years in spite of a new glowplug relay I ordered a set of these twin coil glowplugs but my 'Bongo friendly' garage refused to fit them. Said they would burn out within a month as they were the wrong voltage. Mazda recommend 11 volt plugs and these were 12 volt. Although my knowledge of electrics is not huge, I would have thought that there might have been problems if the voltages had been the other way round ie using 11 volt when 12 volt were specified. They thought that a solution might be to fit them without the relay, but I wasn't too sure about that.
Needless to say I now have a third set of Mazda plugs fitted at great expense and a set of twin coil plugs sitting on my desk!
Any comments gratefully received.
Graham
Posted: Thu Mar 27, 2008 10:23 pm
by brorabongo
I could be wrong ( and often am) but AFAIK the glowplugs do just that .... they glow, so I dont know how twin coil helps? I take it they heat up quicker? To me twin coil must be made up of two thinner heated wires/Elements? which I would of thought if thinner they could break easier?
Loads of ?'s as I honestly don't know.
Having replaced the bongo's plugs myself, twice now the last time being today, and having only had the bongo since a year last February, I decided to go for NGK's. I did so, as I have only ever read good feedback about them on here. They only cost me £35.81 including VAT, from a motor factors. So we will see. Maybe see you all here again same time next year.
Posted: Thu Mar 27, 2008 10:44 pm
by trevd01
I keep reading about people replacing glowplugs. I have done vast mileages in diesel cars since my first diesel Golf in 1982, and never had to replace a glowplug. I suppose the most miles in one car was about 100k, but maybe over half a million miles in total, with never having a glowplug fail.
Glowplugs are meant to last far far longer than spark plugs on a petrol engine, surely?
What's going on here - I suppose veggie oil may need heating up more to fire, but the Bongo glowplug timer doesn't know you are running veg oil?
Posted: Thu Mar 27, 2008 10:55 pm
by brorabongo
The first time the plugs were replaced, was well before finding out the benefits of burning veg oil. So I can not blame veg oil, just yet.
Posted: Thu Mar 27, 2008 10:56 pm
by francophile1947
Lucky you Trevor - I've had to replace them on every diesel I've had (except my 04reg 1.9JTD Fiat)
Posted: Thu Mar 27, 2008 10:58 pm
by trevd01
francophile1947 wrote:Lucky you Trevor - I've had to replace them on every diesel I've had (except my 04reg 1.9JTD Fiat)
They were all new or less than six months old when I bought them, other than a ten yr old landie and the seven yr old Bongo.
Posted: Thu Mar 27, 2008 10:59 pm
by Peg leg Pete
Does the frequency of use affect the glowplugs, we use our bongo everyday, never(yet) changed plugs, run on same ones for 5 years +
Posted: Thu Mar 27, 2008 11:00 pm
by brorabongo
Peg leg Pete wrote:Does the frequency of use affect the glowplugs, we use our bongo everyday, never(yet) changed plugs, run on same ones for 5 years +
Ours is used almost everyday, and sometimes more than once a day.
Posted: Thu Mar 27, 2008 11:25 pm
by francophile1947
trevd01 wrote:francophile1947 wrote:Lucky you Trevor - I've had to replace them on every diesel I've had (except my 04reg 1.9JTD Fiat)
Mine were all new as well (except one) - I guess it's just pot luck. The one that wasn't new was an old Pug 405 estate with 185,000 miles on the clock when I bought it at the local auction. I just needed an old banger to run rubble etc to the tip whilst I was building an home extension. This came up for sale, sounding dreadful and filling the auction room with smoke!!! I paid £5 for it (plus £30 auction charges), fitted new glow plugs and it ran like a sewing machine
- even took it camping to the South of France.
