Jumpstart from Lesiure Battery?
Posted: Fri Feb 15, 2008 1:52 pm
by Netpest
Hi all
Did a quick search and couldmn't find an answer to this but have had flat battery a few times and was wondering if it is ok to use your lesiure battery to jump start your car?
I don't have the knowledge to figure this out I know lesiure battery are a slow drain not used for strating cars, and there may be issue with the fuses blowing but could i leave the cables on to slowly charge?
Hope not a daft question but as they ar eboth in the front engine compartment it would save me a big headache if i could
Posted: Fri Feb 15, 2008 2:13 pm
by francophile1947
The leisure battery may not have the cranking power to start your engine, but I can't see that trying it will harm your LB. You could try connecting the positive terminals (with very heavy wire) to transfer some of the power from the LB to your starter battery to give it a boost.
Posted: Fri Feb 15, 2008 2:28 pm
by haydn callow
Should be o.k. to do this every so often but not on a regular basis.
Posted: Fri Feb 15, 2008 2:32 pm
by scanner
There shouldn't be a problem.
The main difference between starter and leisure batteries AFAIK is not that the leisure one can't be used for starting, but that the starter one can't (or rather shouldn't, as it will be damaged) be deeply discharged.
An occasional start shouldn't do any harm.
Posted: Fri Feb 15, 2008 2:55 pm
by stringman
Different leisure batteries have different properties. I would check the specifications to be sure. However as mentioned above I'm sure so long as you don't make a habit of doing this you will be ok.
Posted: Fri Feb 15, 2008 9:11 pm
by madmile
A lot of leisure batteries are classed as marine / leisure - got one on my boat and it is used to start the engine, so I cant see what harm it can do.
Posted: Fri Feb 15, 2008 9:19 pm
by timhum
I would use just the red, positive jumper lead. Connect it from the LB positive to the Starter batt positive and wait a bit before cranking the engine. This will put a decent bit of charge into your starter battery so it is less likely to over discharge on cranking the engine and also transfer the charge out of the LB slower during cranking, helping the LB stay healthy longer.
I agree that it is wise not to make a habit of it (but if you are stuck you might not care to take this advice!) and if it happens a lot it may mean that you are due for a new starter batt anyway.
Happy motoring,
Tim
by missfixit70
why is the other battery flattening on a regular basis? do you need to transter internal lights, stereo, blinds etc to run from the leisure battery if it hasn't already been done, or is it time for a new battery?
Posted: Wed Mar 19, 2008 11:13 am
by Netpest
Hi All
Soz to reopen this post and read many others but was given an idea by a garage to fault diagnose. He said to monitor the drain on the battery and take fuses out. when the drain stops i took fuse out of the link which is causing the drain. Will this work and be easy way to find.
Also does anyone know what the charge should be when running the engine from the alternator. and what the base battery drain is and exceptable level is.
Going to have a good go this weekend see if i can see whats happening. Plsu what is easiest way to remove the liesure battery from loop incase the drain is from that or can i check to see if it is getting charge?
Posted: Wed Mar 19, 2008 6:48 pm
by bigdaddycain
So is the main starter battery being drained, or is it simply not "holding" a charge netpest? There is a difference,if one of the plates inside the battery has collapsed,it could "take" a charge, but not hold it...
Have you replaced the battery at all? It's sounding as if the voltage sensing relay may be at fault?
Posted: Wed Mar 19, 2008 7:54 pm
by Foz.Foz
I did this for a while over winter. The main battery would die and I jumped off the leisure battery just enough to be able to start the engine. After a dozen or so times, I had the battery checked and it was fooked. Ended up buying a new one, and have not had a problem since. Guess the cold early mornings finished it off
Posted: Wed Mar 19, 2008 8:05 pm
by bigdaddycain
Yip, once they are on their way out, there's no turning back....
Posted: Wed Mar 19, 2008 8:07 pm
by waycar8
whats your location netpest?, check my thread in freestuff section
