I cant get it up!!!!!
Posted: Wed Jan 30, 2008 11:22 pm
by gaulter
Posted: Wed Jan 30, 2008 11:27 pm
by dandywarhol
Try it with the engine off gaulter, that way you'll hear the motors.
I think the other plug is for the rear beeper but wouldn't swear to it.
Posted: Thu Jan 31, 2008 12:43 am
How long ago did you buy it and who from. Are you able to speak with them and get the history? Dealer? Guarantees?
Should be something we can get to the bottom of - can't be that tricky, it'll just take time and probing. Hopefully fixed for camping season.
Good luck - keep us posted
Posted: Thu Jan 31, 2008 11:41 am
by bigdaddycain
It sounds like the locking mechanism has jammed,Like dandy says, have a try with the engine off,see if you can hear the motors trying to lift the roof...Although, i suspect that if there is a fault in the locking mechanism,the system may be aware of this, and not operate the motors, to avoid straining them?...Just trying to think on my feet here,hopefully somebody else reading this has had a similar problem and solved it , and may comment?
Good luck.
Posted: Thu Jan 31, 2008 6:31 pm
by AndAndDen
gaulter pm'd you
Posted: Thu Jan 31, 2008 7:00 pm
by John the sparky
hello Gaulter,
is it a bit rusty around the wheel arches too?
I'm guessing, but is it the one on ebay last week? If it is, I think he said he'd just had it serviced.
(ooops just read your message properly..... You tried all my suggestions!)
Elevating Roof Problem
Posted: Sat Mar 22, 2008 6:36 pm
by George Charnick
I also have this problem. Exactly the same description.
Bit of a story with this one. Following a battery failure had a jump start after which my side lights and fog stopped working and was traced to a failed relay under the bonnet passenger side wing. Replacement supplied via member of this forum which sorted the problem. However, have just tried the elevating roof which bleeps, light on dash ok, as if it should be going up but no motors.
If anyone has resolved this issue I would be pleased to hear.
Regards
Anybody got any clues
Ive got it up!
Posted: Sat Mar 22, 2008 7:27 pm
by gaulter
Posted: Sat Mar 22, 2008 7:46 pm
by missfixit70
I think getting it up on a regular basis should keep it working & stops it going mouldy too
Posted: Sat Mar 22, 2008 7:49 pm
by maxheadroom
nice one gaulter,
I hope this site helped and hope to hear more from you.
PS welcome on board
Posted: Sat Mar 22, 2008 8:02 pm
by Peg leg Pete
missfixit70 wrote:I think getting it up on a regular basis should keep it working & stops it going mouldy too
are we still talking about the roof here
Posted: Sat Mar 22, 2008 8:20 pm
by heatherpetch
what else could we be talking about
Posted: Sat Mar 22, 2008 10:51 pm
by lizard
Peg leg Pete wrote:missfixit70 wrote:I think getting it up on a regular basis should keep it working & stops it going mouldy too
Ooeer Matron
