Thermostat or No Thermostat? - That is the question
Posted: Wed Jan 23, 2008 11:57 am
Hi again,
For those who have not been following my previous post about odd temperature readings.....
http://www.igmaynard.co.uk/bongo/forum/ ... hp?t=17850
.....my mechanic has concluded that my recently installed, refurbished engine does not have a thermostat; however, the temperature gauge is working accurately (he is however checking that this is the case). Therfore, he says I basically have 3 options to proceed with.....
(1) Continue to run the engine without a thermostat - My mechanic says he has run in to a few bongos with overheating problems that relate to faulty thermostats (I assume he feels there is something inherently wrong with bongo thermostats as opposed to thermostats themselves). He says this would be like an insurance policy against my engine being a victim of a thermostat related overheating and provided I can live with the heaters taking a while to warm up, it won't do the engine any harm.
(2) Install a thermostat - This is my favoured option. Engines I assume are supposed to have one and I bought one in advance which will arrive at my mechanic's today. Assuming the temperature gauge is working fine and I install a temp. sensor like the one Missfixit did, surely I can pick up the warning signs of an engine overheating should the thermostat go faulty. A colleague informed me that part of the thermostat's job is to keep the engine at an optimum temperation for efficiency (is this true?) and that if it runs at a cooler temp., it may be using more fuel than it should. Also, I'm about to start a 7-week spell boarding in the French Alps so I reckon I'll be quite keen to have the heaters warmed up ASAP.
(3) Install a thermostat, but drill a hole through it - or something like that my mechanic said. Means the thermostat won't operate exactly how it should, but in case it does become faulty, it won't fully block the coolant flow and therefore reduces the chance of overheating. Sure I read this being done by someone on another thread but I can't find it anymore. Anyone out there run there bongo with a thermostat modified like this?
Thanks again for your advise in advance.
