Fuel Gauge
Posted: Wed Jan 16, 2008 11:45 pm
by bighairypict
Anyone noticed a fuel gauge that seems sticky after filling up?
Any other time it seems responsive enough - goes down steadily while driving, drops to the bottom when the ignition switch goes off, comes back up to where it came from when switching back on but after refueling it starts pretty much where it was before and only creeps up slowly.
Is this any indication of problems to come or nothing I should worry about?
Posted: Wed Jan 16, 2008 11:54 pm
by madmile
Are you sure it goes down when ignition switched off - I thought it stayed put at all times. Also it should be very slow to respond due to the damping built in.
Posted: Thu Jan 17, 2008 12:04 am
by dandywarhol
Sounds like a dodgy earth. Under the middle seats carpet you'll find a removable panel, under that is the sender unit. Make up a seperate earth and attach it to a sound earth point nearby and the job's a carrot
Posted: Thu Jan 17, 2008 12:38 am
by bigdaddycain
Mine doesn't drop with the ignition off either....
Posted: Thu Jan 17, 2008 9:21 pm
by bighairypict
Right enough, now that I have looked at it more closely it is the temp gauge that drops when I turn off.
Put fuel in this afternoon but the needle took a few miles to go up from where it had been before.
Posted: Thu Jan 17, 2008 9:29 pm
by haydn callow
perfectly normal
Posted: Sat Jan 19, 2008 2:56 am
by bigdaddycain
It does take a while to kick in bighairy...Glad its not just mine, must be a bongo thing...
Posted: Sat Jan 19, 2008 12:35 pm
by bighairypict
It seems we are all still learning about this vehicle, Bigdaddy
I would conclude this is, as Haydn commented, "perfectly normal"
Thanks for the replies folks
now on to the next discovered quirk.....
