side light bulbs
Posted: Wed Jan 16, 2008 10:21 pm
by Bongo Boozer
Good Evening,
Could someone tell me how to change these bulbs. I have downloaded the fact sheet (PDF) and it is a jumble of symbols (it could be because i am using a MAC). I have also searched the forum to no avail.
I had a quick look on Sunday in the rain but I was getting to wet (so I went back to building my ARK).
Many Thanks
Steve
Posted: Wed Jan 16, 2008 10:28 pm
by daveblueozzie
if you mean the front side light bulbs, there is a screw on the top that lets you take the lens away from the body ,then you can get to the bulbs.
if you mean the rear bulbs there are two screws holding the unit which you then slide sideways to remove (carefully), then change the bulbs.
Posted: Wed Jan 16, 2008 10:29 pm
by B*Witched Blingo
Mr A changed mine on Saturday.. 2mins of a job.. Not that that helps u.. U will no doubt have an answer before he comes in...
Good luck
Posted: Wed Jan 16, 2008 10:30 pm
by Bongo Boozer
ah the screw i managed to see
sweet
thanks
steve
Posted: Thu Jan 17, 2008 12:53 am
by bigdaddycain
Give the light unit a wiggle to help free it from the front wing steve...some are easier to remove than others.... :wink:
