one simple qustion. EGR. Where is it?
Posted: Fri Jan 11, 2008 8:06 pm
by spitineye
hello all.
query as above.
effient as a German i am!
Posted: Fri Jan 11, 2008 8:07 pm
by spitineye
(efficient)
how un-German of me!
Posted: Fri Jan 11, 2008 8:08 pm
by greg
more to the point what is it
Posted: Fri Jan 11, 2008 8:20 pm
by spitineye
news to me too until i read Torchwood's 40mpg thread. it's the Exhaust Recirculation Valve. Required in Japan, but not here. lots of info on it here, but i can't seem to find anything about it's location
by scanner
If you do a search on "EGR" loads of threads will turn up.
And lots of pictures in some of them.
Posted: Fri Jan 11, 2008 8:29 pm
by greg
ah i think its the engine warmer switch, i've got one but most people recomend not to use it
Posted: Fri Jan 11, 2008 8:37 pm
by spitineye
cheers Scanner, did a search for EGR this time instead of exhaust recirculation valve. much more fruitful!
Posted: Fri Jan 11, 2008 8:38 pm
by scanner
Nope, that's an engine heater.
EGR is on the engine itself (and before the exhaust system) it recycles a proportion of the exhaust gases straight back from the exhaust manifold to the inlet manifold to reduce (allegedly) combustion temps and thus reduce the production of NOX.
http://en.wikipedia.org/wiki/Exhaust_gas_recirculation
Posted: Sat Jan 12, 2008 12:31 am
by bigdaddycain
The main problem with the EGR system is that its efficiency is questionable as time goes by...
Mine was fine, but i decided to ditch the entire system (just in case) using Nick Skidmore's EGR blanking/removal kit.
The engine is now a little more responsive,and i dont have to worry about the valve in the EGR sticking open now...
It certainly hasn't adversely affected the emissions.
