Coolant leak - worst feared - please help(with pics!!)
Posted: Thu Jan 03, 2008 10:08 pm
by ADAMD
Having had an overheating episode caused by pin-hole in
large metal pipe, I now have a coolant leak appearing from behind the
lower large pulley at the front of the engine.
It is impossible to get a good look at where it might be coming from,
can anyone offer any advise?
I am fearing the worst
Many Thanks
Adam
Image[/img]
Posted: Thu Jan 03, 2008 10:18 pm
by Ralph
Water pump ???
Posted: Thu Jan 03, 2008 10:59 pm
by haydn callow
Water pump ! agreed
Posted: Thu Jan 03, 2008 11:19 pm
by Harry
Yup...water pump...easy (if not cheap) to replace.
good luck
H
Posted: Thu Jan 03, 2008 11:23 pm
by ADAMD
Thanks chaps, I had a look at what I thought was the water pump area, but could see very little.
Does anyone have a good picture showing the waterpump position in relation to that large pulley.
Thanks again.
Adam
Posted: Thu Jan 03, 2008 11:31 pm
by alphabetter
Water pump is item 15-100T on this diagram:
http://www.lushprojects.com/bongopartsm ... no=.html#3
by Harry
Not very good at describing just where but I think its up a bit and to the right.
My pump bearings went as a result of the belts being ovetightened when replaced on a service. Started with a little leak like yours then failed catastrphically in southern France. French garage replaced pump...filled up the water and bled the system and away we wnt all the way home.
cheers
H
Posted: Thu Jan 03, 2008 11:37 pm
by ADAMD
I am very grateful for everyone's assistance.
Once I locate the pump, where should I look for a leak?
The trickle is very definitely on the right of the center of that large pulley, the water pump appears to be on the left hand side - could it track across??
again.
Adam
Posted: Fri Jan 04, 2008 9:32 am
by Harry
The leak appears to come from the centre hub of the pump.
With the engine running it sort of sprays a fine dribble around the area then this pools wherever is handy.
H 8)
Posted: Fri Jan 04, 2008 11:12 am
by neepboy
yeah looks like the water pump I had to replace a hose and pump 2 weeks ago..in the freezing cold..and at night due to work/christmas commitments...and outside as the bongo is too tall for the shed.. :( .NOW FOR THE GOOD NEWS IVE GOT A BRAND NEW PUMP AND GASKET BOUGHT IN ERROR (ITS A LONG STORY) IF you want it i'll let you have it for less than I paid for it :P and if you want a step by step guide to how I relpaced my pump give us a shout...It's Christmas after all!!! :wink: (almost)
Posted: Fri Jan 04, 2008 12:38 pm
by ADAMD
Thanks neepboy, I have PMed you.
Adam
Posted: Fri Jan 04, 2008 4:01 pm
by haydn callow
that brought a tear to my eye !! not suprising though on this forum.
Much better than reading all about the FLARE up before Christmas.
Balance of the world is now restored.
Posted: Fri Jan 04, 2008 4:43 pm
by francophile1947
haydn callow wrote:that brought a tear to my eye !! not suprising though on this forum.
Oh yes indeed :D :D :D
Posted: Sat Jan 05, 2008 12:38 am
by coco bongo
Sorry about your predicament!. If its any consolation to you mines in the garage at the moment with head gasket problems.
I too have had the waterpump done. Also a rad and thermostat. Im hoping that after this is done, that will be it. PLEASE!!!!!!!!
Hope you get yours sorted with ease, and If it is a fresh import get all that coolant out, flush it through, and most important get it bled PROPERLY.
Say it to everyone, but trust me it is very worth it. And even to say treat yourself to a new radiator.
Best of luck
Darren.
