Rear wheel bearings
Posted: Thu Dec 06, 2007 5:07 pm
by jax
I have a nasty suspicion that I have a failed bearing on the rear wheel (s)
Does anyone know if the half shaft has to be removed to replace a
bearing and has anyone done this job themselves? - Why me Lord - I bin
good !
Posted: Sun Dec 09, 2007 12:14 pm
Just catching up old posts. Surprised you didn't get a reply to this one. I'm sure it was discussed (and techie advice made) on a thread some while back. Have you had a search on BF?
Posted: Sun Dec 09, 2007 12:21 pm
by dandywarhol
The half shaft does need to be removed having dismantled the brake assembly first. The bearing will need pressed off the shaft.
Best to replace the oil and dust seals at the same time - the oil seal is separate from the bearing and located in the axle casing.
Thanks to lushprojects again for the diagram :)
http://www.lushprojects.com/bongoparts/ ... 0axle.html
Posted: Tue Dec 11, 2007 9:38 pm
by ebygum32
When i replaced my rear axel oil seal took about 2 hours so stick another hour on top and that should be your job time just to give you an idea
