newbster with question/problem as always !
got a bongo and its boiling up . heater is cold inside vehicle and water and oil are perfect... so , is it a thermostat or what else can it be ??? its a royal pain ! 60 k miles and pristine other wise (apart from roof not going up , fuse ? ) ps, i am brand new to these and have not a clue lol !
- Peg leg Pete
garage is busy till monday but i have had a poke about... found a big hose has been cut and joined on the drivers side (pics here) . so what is the bleeding process ? it also seems not to be charging and when running, the lights are crap and alt light is on although all belts are fine....feel free to point out any issues you see from my pics !
You say the alternator light is on, is the sediment light on also? if so alternator is goosed & needs fixing or replacing, not sure if they are fixable as peg leg pete is investigating at the moment. have you measured the voltage with & without the alternator running?
I hope you are planning on replacing that hose asap have pm'd you with the seesaw bleed method - couple of other methods dotted about on the forum - one from Bigdaddycain if you mant to do a search - make sure you use AND in between words to refine your search. Good luck with it
it seems ok to start with all lights are dim with constant clicking inside bonnet but that has stopped since we put the batteries on charge and tried it just now and all lights went out so all is well there as engine was running fine . just need to replace the hose and do the coolant bled properly tomorrow...thanks to all the people who gave solutions to this quickly.
