Page 1 of 3
Whining on
Posted: Mon Nov 05, 2007 5:16 pm
by parabat2
I'm not happy. :-(
Over a year ago I had to replace my front diff and viscous coupler. (See http://www.igmaynard.co.uk/bongo/forum/ ... highlight= for the gory details.)
The transmission system is now whining quite loudly again, although the van drives OK. I'm not sure I can face having the transmission system done yet again, with no guarantee that it will not fail again in a years time.
Indecision time - what should I do?
Posted: Mon Nov 05, 2007 5:18 pm
by dandywarhol
Check it isn't just uneven tyre wear "blocking" causing the noise.
Disconnect the front propshaft and see if the noise has gone and leave it off.
Posted: Tue Nov 06, 2007 11:49 am
by parabat2
I'm not sure what you mean by this. It doesn't sound like it is coming from the tyres though.
My back "went" today, so I won't be doing any work on the van for a while. :-( but when I do, how do I disconnect the prop shaft? Do I have to take the whole thing off?
Thanks for the help.
Posted: Tue Nov 06, 2007 1:34 pm
Oh dear parabat2, you can join me in the out-of-action-due-to-my-back-which-might-be-due-to-my-Bongo Club :lol: :( :lol: :( 8)
Posted: Tue Nov 06, 2007 1:45 pm
by Ralph
Ours had a whine for all the world like a diff but a change
of front tyres and it as completely gone.
Posted: Tue Nov 06, 2007 1:51 pm
by parabat2
Must be the only exclusive club that will have me! :-)
Actually, it was due to a Polo (car, not mint).
Posted: Tue Nov 06, 2007 2:16 pm
Ok, we'll rename it the 'out-of-action-due-to-my-back-which-might-be-due-to-my-bl**dy-car Club' 8)
Posted: Tue Nov 06, 2007 6:17 pm
by parabat2
I will try rotating the tyres around and see if it changes the whine.
Thanks for the suggestion.
Posted: Tue Nov 06, 2007 6:26 pm
by dandywarhol
Maybe I've used the wrong terminology here........ I call "blocking" when the tyres wear unevenly and they start to tear up into blocks in the tread like an off road tyre
Rebuild
Posted: Thu Jan 10, 2008 5:16 pm
by parabat2
Finally got the Bongo to a transmission specialist, who is now rebuilding the rear differential. I'm not sure my pockets are big enough to keep this vehicle! :cry:
Posted: Thu Jan 10, 2008 6:02 pm
by londonron
i am about to get mine done so any info on costs would be great. what mine does is a nasty whinning noise which goes as soon as you lift of the accelorator. it is a constant thing and comes and goes each time you touch and remove the accelerator so i am guessing one of you smarty pants will know what it is,
Not Diff
Posted: Thu Jan 10, 2008 6:13 pm
by parabat2
I suspect your problem isn't coming form the differential because it isn't constant at a constant vehicle speed. Mine whined as the vehicle gathered speed, but didn't change when I took my foot off the accelerator.
Perhaps a belt or something similar?
Posted: Thu Jan 10, 2008 7:05 pm
by francophile1947
londonron wrote:i am about to get mine done so any info on costs would be great. what mine does is a nasty whinning noise which goes as soon as you lift of the accelorator. it is a constant thing and comes and goes each time you touch and remove the accelerator so i am guessing one of you smarty pants will know what it is,
Sounds like it might be the start of a manifold stud going.
Whinning On
Posted: Thu Jan 10, 2008 7:45 pm
by chrisd2211
Ok so I decide to use my Freeda today for a trip tp Plymouth(this is the first time she has had a run since i bought it in December) at approx 100km per hour I am gettin the most annoying droning noise however if you push her to around 110 km it dont go but it does go a lot quieter unitil your speed drops to around the 100 km again and below, I also noticed that when I stopped at the traffic lights it was obviously quiet until I pulled off the Droning noise was there at low speed granted not as loud as at 100km. the reason for the post is that I have a small amount of warranty remaining take her back I hear you say thats fine but what im affraid of is that I would hate to think they would do a quick fix on it to see out the remaining warranty and then leave me with a huge pocket emptying bill!!! what I need to do is try to make them aware I know whats wrong with her and duly ask them to put it right. I would appreciate all your thoughts on this. :roll:
Posted: Thu Jan 10, 2008 8:00 pm
by dandywarhol
4WD Chris? unusual tyre wear pattern?? See above posts
