Front n/s indicator light stays on
Posted: Thu Nov 01, 2007 5:12 pm
by aitch
when locking the Bongo the indicators all flash twice, when unlocking they flash once. At times whilst locking her up the near side front indicator stays on until I unlock and re-lock again any ideas whats gone wrong? it only does this now and again.
Light on
Posted: Thu Nov 01, 2007 6:01 pm
by Socket Set Sue
Check to see if your indicator stalk below the sterring wheel is in the 'I am turning left' poition.
Posted: Thu Nov 01, 2007 6:17 pm
by Dave up north
My indicators only work intermittantly!!!
Posted: Thu Nov 01, 2007 6:53 pm
by aitch
indicators work fine just the n/s/f stays on when everything is turned off and i have locked up!!!
Posted: Thu Nov 01, 2007 8:38 pm
by rwill19050
Dave up north wrote:My indicators only work intermittantly!!!
I think they missed that one
Posted: Sun Nov 04, 2007 8:55 pm
by aitch
which one? where is it please?
problem still happening at times?
Posted: Sun Nov 04, 2007 8:57 pm
by pippin
The original Bongo Mazda fitted central locking does not interact with the lights so you must have an after-market system fitted.
Posted: Sun Nov 04, 2007 10:12 pm
by Pete & Sue
Dave, Erin. My indicators only work intermittently. they keep going on - off - on -off.
Does that mean that they are broken?
](./images/smilies/eusa_wall.gif)
Heeeelp!
Posted: Sun Nov 04, 2007 10:35 pm
by clogger
strange one
if it was a sticky relay would`nt both front and rear indicator stick on ??
how is the aftermarket central locking wired in ??
most wire it into the hazard circuit to flash the lights, then surely if the aftermarket unit was faulty all four indicators would stay on
i take it you have tried changing bulbs cleaning contacts on the light fittings that sort of thing
giving it a whack with a big hammer
Posted: Mon Nov 05, 2007 1:12 am
by bigdaddycain
It sounds a bit like a "look at me there is something amiss" type warning from the alarm...
Have you any instructions/manual for the alarm Aitch?
Try looking at the troubleshooting section if you have any.
Posted: Mon Nov 05, 2007 2:50 pm
by smartmonkey
As Pippin mentioned it is an aftermarket system. I would check the alarm and new wiring first. They usually arent installed very well so you will probably have to improve a few bits and pieces to get the solution.
Posted: Mon Nov 05, 2007 4:48 pm
by aitch
thanks for all the replies I have no instructions for the alarm I thought it was a standard fitting so will spend some time this weekend looking at all the wires. Will report on progress when I achieve anything useful for others.
