Knocking noise ... was the aerial against the roof
Posted: Tue Oct 23, 2007 5:05 pm
My bongo was knocking away a treat. It was hard to pin point where from. Driving it sounded like it was coming from around me, possibly under my seat, for the passenger it sounded a little further back. It happened most on bumpy roads, but it only really happened at slower speeds.
Searched the forum for "knocking". Loads of messages popped up suggesting it was quite likely drop links, as this was a common fault. So i splashed out and bought front and rear drop links and front and rear anti roll bar rubbers. Installed it all, which took about a morning because i had to chisel off one of the nuts on the front drop links. Went for a test drive .... knock knock knock.
By this point I am getting nervous that its something more serious. I've planning to live in it for 6 months next year around europe and I don't want to have to do a serious repair in darkest croatia.
I was driving along a bumpy road, knocking away and getting worried, when i decided to stick my ear against the window to try and help track down the exact location. Then it hit me what it was. It was the plastic end of the fully extended aerial knocking against the roof. The pivot at the bottom of the aerial is no longer strong enough to hold it up so it ends up falling back to the horizontal position where is movement knocks it against the roof.
The relief was overwhelming, so much so that I didn't even care that i had needlessly spent £60 on drop links and rubbers (slightly firmer ride now though).
So, with the benefit of hindsight, if you have a knocking bongo and it sounds like its coming from somewhere near the driver, first check its not your aerial flapping about against the roof.
