sounds like pinking
Posted: Sat Oct 20, 2007 7:03 pm
by gina
Help why do my bongo sound like its pinking???? :cry:
Posted: Sat Oct 20, 2007 7:17 pm
by timhum
Hi Gina,
Just a thought. Check your coolant level, when it runs low, there is a ticking noise from behind the dash particularly when accelerating.
It might sound like pinking.
Cheers,
Tim
Posted: Sun Oct 21, 2007 12:14 pm
Are you running on pure diesel? I listened to a couple of BF members recently saying they thought Bongos running with veg oil in the mix could sound a bit like they were pinking at times. I've not used veg oil yet and I have no idea whether this is sound thinking, or if it matters, but I mention it just in case. No doubt veg oil users with confirm either way
Mike 8)
Posted: Sun Oct 21, 2007 1:37 pm
by dandywarhol
Could be the start of the exhaust manifold gasket/stud leaking causing a high pitched "twittering"
Pinking
Posted: Sun Oct 21, 2007 1:53 pm
by Socket Set Sue
More than likely a glow plug failing. :cry:
Posted: Sun Oct 21, 2007 5:56 pm
by gina
Coolant low thank god thanks a lot for replies
Gina
Posted: Sun Oct 21, 2007 10:56 pm
by dandywarhol
Find out why it's low ASAP Gina or you risk damaging the engine. It shouldn't "gurgle"
Posted: Sun Oct 21, 2007 11:23 pm
by bigdaddycain
You hit the nail on the head there Timhum :wink:
I'd have never thought the two were connected :shock: You live and learn eh?
Posted: Sun Oct 21, 2007 11:42 pm
by Harry
Damn...you've spotted my secret method of telling when my coolant needs topping up.
Not sure why it does it but the sound is very distinctive and has pre warned me on a few occasions of trouble ahead with leaky pipes. Problem is that it took me a couple of ovrheats to realise what the noise meant :oops:
Sounds to me like trickling water just after start up but when you look under the van there is no sign of any water dripping anywhere.
H 8)
