Oil Change
Oil Change
How easy / is there instructionctions on how to do an oil change? At one every 3,000 miles I can imagine not difficult but expensive if a garage has to do it 7 times a year...
David Edwards
Why at 3000 miles the bongo is not that delicate I do mine every six months and it has been fine for four years. Happy motoring. Forgot to say I just had mine done after six months bought the oil at Lidls, seems good stuff too, garage was impressed with it only was £6.00 for 5 litres, oil change cost a tenner and the filter £8.00 at my local motor factors. Can't do it meself anymore cause of the arthritis...oh the joys of getting old.
- haydn callow
- haydn callow
- haydn callow
Oil Change
Short Description How to do an oil change.
Fault Description Time to change the oil again, it`s very simple if not a bit messy.
Links http://www.igmaynard.co.uk/bongo/forum/ ... oil+change
Solution Details Mazda quote 10w/30 oil for the Bongo. This oil type is available almost anywhere now even Tesco stock it.
Buy a cheap washing up bowl and a funnel.
Locate the sump plug(nut) place the bowl under it I also put a bin liner on the ground just incase, undo the nut using a 19mm socket.
Drain the oil into the bowl and then into the empty oil container when you have refilled the Bongo. You may need an extra empty 2 litre drinks bottle. Your local recycle centre should have a facility for waste oil.
You should also change the copper washer on the sump plug to avoid any leaks.
A word of warning on replacing the copper washer, get the exact size as an oversize washer will impinge on the sump.
Don`t forget to change the filter, it is supposed to be changed every other oil change.
The oil cap is located under the passenger seat.
It takes 6L to fill a Bongo but always check the levels after filling and top up if required.
- haydn callow
Ralph
kawasaki kid
- Tribal Elder
Socket Set Sue
Oil
Lidl 15/40 oil is only API CF4 (introduced 1990), you can get API CH4 (introduced 1998) at Asda for same price.
Latest API is CHJ (introduced 2006) see:-
http://new.api.org/certifications/engin ... de2006.pdf page 3.
pistonbroke
- alphabetter
See the "Lubricants" fact sheet for a long discussion on this and while I have the floor see the "Oil Change" fact sheet for how to change the oil!pistonbroke wrote:Er......it is supposed to be 5/30. That's what the manual says anyway. When I suggested to my mechanic that I didn't think it would matter that much, he went red and gave me a bollocking.
flippa
i just finished my first diy oil change on the bongo ,using the pela
yawn
i used castrol gtd plus 10w-40 ...api cf....acea b3.....it was old stock sitting on the shelf gathering dust at 3.99 for 5 ltrs
i helped myself to 10 ltrs ..i never changed the filter this time ,was changed in april, will do next oil change . not a great acheivement in the scheme of things but for me its the first time ever i have changed the oil on any vehicle
and judging by what i used to get charged the pela has just paid for itself
