Where can I buy SAE90 GL6 for my LSD Bongo?
Posted: Tue Sep 18, 2007 4:18 pm
by lmulhall
I've tried looking on the Bongo Bits site, Googled it, and e-mailed some companies but cannot find out were to get SAE90 GL6 oil. Does anyone know where it is available?
Many thanks,
Luke
Posted: Tue Sep 18, 2007 11:07 pm
by RobnKathryn
I had the same problem.........it seems that GL6 was a spec which never really caught on for some reason, hence no-one sells it because it doesn't sell!
I ended up using Castrol Differential SAF-XJ in my rear limited slip diff., even though it's still GL5 spec it seems to be specially formulated for lsd's.
You can just use regular GL5 in front diff and transfer box........if you don't have lsd on rear you can use GL5 in there too.
Rob
