AIR PIPE ??
Posted: Sun Aug 26, 2007 11:11 pm
by daveblueozzie
Under the front drivers seat sits the air filter, if you follow this big pipe round towards the rear of the engine there is a small pipe coming out of it, this small pipe goes near the egr unit (which i no longer have) but not into it.This small pipe has a one way filter on it.
Now eventually to my questions, what is this pipe for ? what does it do ? what is it called ?(if it has a name) and can i get another from somewhere as ive slightly knackered mine.
Posted: Mon Aug 27, 2007 2:36 pm
by jimsmimm
have never came across it' could it simply be a drain hose... to let any moisture or fuel trapped in the airbox drain away... :?:
Posted: Mon Aug 27, 2007 9:01 pm
by daveblueozzie
not a drain hose it comes out of top of air pipe into some electrical gubbins ,will try to get some photos .
Posted: Mon Aug 27, 2007 9:32 pm
by RobnKathryn
Dave
I'm not sure what it is, but I broke mine too! I ran the van for 20k miles without it and didn't notice anything amiss. Apparently they break easily and cost about £36 to replace from Mazda. My egr was disabled, so my guess is that it has some sort of purpose related to the egr.
There's been discussion about this item before and no-one seemed to know what it is really!
Rob
Posted: Mon Aug 27, 2007 9:41 pm
by daveblueozzie
it has been fixed temporarily by black insulation tape ,like you said dosent seem to do anything.
Posted: Tue Aug 28, 2007 12:24 am
by bigdaddycain
I forgot to ask you earlier dbo,does the engine revs drop on tickover,when the aircon is switched on?
Just a thought....
Posted: Tue Aug 28, 2007 2:27 am
by antz
its not the breather pipe that goes into the head is it? usually you have few, or at least one pipe going from just under the rocker cover to your intake. it doesnt really do anytyhing, when people modify their intake, they usually stick a real small airfilter onto the rocker breather pipe. i think thats what you are talking about. in that case dont bother fixing it, just block it up and she'll be right :D
