Page 1 of 2
Throttle sensor compensation resistor and NE sensor
Posted: Sat Aug 25, 2007 3:35 pm
by corblimey
I've been poking around under the lid of my van this afternoon and come away with more questions than answers.
1) My manual refers to an NE sensor. What does NE stand for and what does it do?
2) As I press the throttle and measure the throttle position sensor at 2.15v and small ticking sound starts like a small pump or something. As I press the throttle further the noise continues until about 3.15v when it stops. What could it be?
3) What is the throttle sensor compensation resistor for?
4) I measured said resistor and got a reading of about 840 ohms. The manual says it should be 0.1 ~ 2.5 ohms. Obviously that's a significant differernce but could it be a typo (missing k perhaps)? Would a couple of kind souls be prepared to measure theirs so we can see work out if the book is right or whether I've got a lemon.
To measure the resistance open the drivers seat and locate the snesor block in the following pic
Take it apart and measure between pins "D" and "F". In the following picture that's the two central pins in the the bottom row of the socket.
Thanks in advance
Posted: Sat Aug 25, 2007 8:16 pm
by brorabongo
Are you on about the "466 TA2" thingy? If so mine is a "469 AL2" thingy
and I have no connections on "D" and "F", but between "A" and "C" I get 1.3K ohm. "A" and "C" being the two blue wires comming from the "469" Thingy, shown below.
Posted: Sat Aug 25, 2007 10:31 pm
by corblimey
Cheers for that Brora.
Unfortunately that's not the thing I'm on about but thanks for making the effort anyway. Your 469 and my 466 are the Throttle Position Sensor (TPS).
If you look in my first pic there is an orange wire and a blue wire coming out of the cconnector block. These are connected to a resistor that is clipped on to the lump a little further back from the TPS and lower down. Got no idea what it's for though.
Posted: Sat Aug 25, 2007 10:59 pm
by brorabongo
Mines different
No
blue and
orange
and no bright
RED in my picture either
So I'm going to be as much use to you as............................(you can use your own imagination for a useless item)
Is it an Automatic thing? as mine is manual.
Posted: Sat Aug 25, 2007 11:40 pm
by corblimey
hmmm, yes mine's an automatic. fairly important fact I nelected to mention!
Posted: Tue Aug 28, 2007 7:57 pm
by dandywarhol
1090 ohms on mine corblimey
Posted: Wed Aug 29, 2007 7:46 am
by corblimey
Cheers Dandy. Thanks for making the effort, appreciated.
So, it's looking like there's a printing error in the manual. Would someone else be kind enough to measure theirs so we can confirm it.
Can anyone shed any light on my other queries?
Posted: Wed Aug 29, 2007 5:08 pm
by francophile1947
Posted: Wed Aug 29, 2007 8:59 pm
by dandywarhol
Where are you taking the voltage readings from cor - I'll check mine if you want.
Re: Throttle sensor compensation resistor and NE sensor
Posted: Wed Aug 29, 2007 9:54 pm
by alphabetter
corblimey wrote:I've been poking around under the lid of my van this afternoon and come away with more questions than answers.
Don't know what NE stands for. What it does is to measure the RPM of the engine. A few people here have had problems with faulty rev counters caused by a defective NE sensor.
I suspect its a coil that gives a little pulse each time some marker on the crank shaft goes past.
Posted: Wed Aug 29, 2007 10:57 pm
by corblimey
Thanks Alphabetter that's solved one little mystery then. Not too bothered knowing what NE means now I know what it does.
Dandy; I'm measuing the TPS voltage at the ECU end of the loom as I mentioned in this thread
http://www.igmaynard.co.uk/bongo/forum/ ... hp?t=14174
My TPS voltage is fine appart from when the TPS is playing silly beggers. I needed to verify the throttle compensation resistor value (which is something else but I don't know what) which you've already done for me.
I'm confused since the workshop manual says one value yet you and I are reading another.
Out of interest you could hook your multimeter up to the TPS and press the throttle until you get a reading of about 2.5v and see if you get the ticking noise.
Posted: Wed Aug 29, 2007 11:57 pm
by dandywarhol
Ill try it tomorrow cor.........I couldn't find the other post, thanks for that.
By the way, how the hell did you get up to 13,664 posts
Posted: Thu Aug 30, 2007 6:58 am
by corblimey
Simply by repeating the following mantra everytime some one posts about leisure batteries:
don't do it like that (dumb relay), do it like this (VSR)
Seriously though.... remember those missing tech posts a few months back? Well, I had to dig around in the bowels of the forum software to restore about 13,500 of them from a backup and mysteriously
the forum counted them as my posts!
Posted: Thu Aug 30, 2007 1:32 pm
by corblimey
I get the feeling I've managed to confuse people with regard to what to measure
So, just to clarify...
I'm after the reading for the throttle position compensation resistor. It's not the same thing as the throttle position sensor (TPS).
In my photos in the original post you can see the TPS, it has 466 TA.2 printed on it. This is
not the thing I'm interested in. The photo was supposed to be of the connector block but the TPS found its way into the piccy. The fact that it appeared in the photo may have led to the confusion.
The throttle position compensation resistor is a fixed resistor and judging by brorabongo's reply it is a part specific to auto vans.
Ok; clear as mud?
Posted: Thu Aug 30, 2007 4:29 pm
by dandywarhol
Errrrrm...........but do you still want the voltages checked too.
