Rear fan blower
Posted: Tue Aug 14, 2007 6:54 pm
by matcor
Hi Everyone,
I have been searching for information regarding the rear fan blower, it doesn't seem to be working anymore. The rear heater switch on the dashboard lights up, but nothing happens! My front one packed up and I replaced the resistor, which did not fix the issue as the motor had seized, I therefore replaced that and all is working well!
Thanks to this thread
http://www.igmaynard.co.uk/bongo/forum/ ... t=rear+fan
I have located where the rear fan is, but before I take off the panel I wanted to know is there a similar resistor that could need replacing and where is this located?
Any help would be most appreciated!
Thanks.
Maurice
Posted: Tue Aug 14, 2007 7:33 pm
by manners
I think the rear fan only works if the swicth on the dash and the front fan are on together.
Posted: Tue Aug 14, 2007 7:51 pm
by missfixit70
My rear fan works independantly of the front fan if dashboard switch is on of course
Posted: Tue Aug 14, 2007 8:33 pm
by bigdaddycain
On my bongo,the rear fan switch doesn't operate unless the front heater is switched on, i.e. you cant JUST have it blowing at the rear,the front four position switch acts as the master switch.
Posted: Tue Aug 14, 2007 8:35 pm
by missfixit70
Mines the digital climate control, must be different
Posted: Tue Aug 14, 2007 8:37 pm
by bigdaddycain
Aha!...mines the manual one...
Re: Rear fan blower
Posted: Wed Aug 15, 2007 5:26 pm
by waycar8
matcor wrote:Hi Everyone,
Thanks.
Maurice
hi Maurice, the answer to your question is yes, if you strip the cover housing off the rear controlls, and under that there is a resistor (same as the front one), cant remember exactley where it is but i did see it when i took off the plastic housing to see if i could see where the aircon gas was leaking from
regards Wayne.
Posted: Wed Aug 15, 2007 6:25 pm
by matcor
Thanks all, but there is definitely a problem with the blower.
Wayne: Do I need to take the whole panel off as indicated in the image on this thread
Or can I simply remove the control panel housing to get to the resistor?
Regards,
Maurice.
Posted: Wed Aug 15, 2007 7:17 pm
by waycar8
matcor wrote:Thanks all, but there is definitely a problem with the blower.
Regards,
Maurice.
Well, i just took the whole panel off as i was looking for a leak but if you take the control panel bit off, you will be able to get to it, (if i remember rightly)
Posted: Thu Aug 16, 2007 6:28 pm
by matcor
Thanks, i'll give it a go.
