no aircon??
Posted: Thu Jul 26, 2007 8:34 pm
by xpanse0
Can any one tell me what the possible problem is with my air con. It was working but it isn't as off a couple of weeks ago.
Thanks in advance
Steve
Posted: Thu Jul 26, 2007 8:44 pm
by francophile1947
Need more info - do you mean it's no longer cold, or the fan isn't working?
Posted: Thu Jul 26, 2007 8:45 pm
by dreamwarrioruk
they will not work if they are out of gas, lift the bonnet and look to the right hand front side of the radiator, there is a small round block with a few pipes comming out of it. there is a sighthole in the top of it, someone said that changes colour when no gas in,they also said that if there is no gas then the aircon will not work to protect the system.
im sorry i cant help much but it might be worth getting the levels checked out and check for system leaks.
by Naughtydog
can you be anymore specific,
do you switch it on and it doesnt work?
does it not get cold enough?
does the blower still wok on all speeds ?
give us a clue about what exactly doesnt work and then we can take it fom there.
