Switch question - go on, have a giggle
Posted: Sun Jul 22, 2007 1:49 pm
I've a newly bought Bongo and there's a switch on the dash that I can't work out. I dont think it's an original, but it has been professionally fitted. It has a rubber grommet securing it in the hole in the dash.
This switch is to the left of the rear heater/fan on/off. The switch is round and red, about 1cm diameter. It looks like it might be one that should light up when operated but it doesn't.
My 1st thought was maybe a manual switch for the engine cooling fan, assuming that is electrically operated. Well I 've tried it and that doesn't seem to be the case. In fact it doesn't seem to do anything.
In the rear cabin, Just above the rear cabin heater/fan switches on the OS of the middle row is a similar looking green light set into the side panel trim. It's the same diameter and with a similar grommet to the one in the front. The two look so alike I wonder if they're connected. The green light has, thus far, never come on.
Any ideas??
Its going back to the dealer this week for a few snags to be sorted so I'll ask them too.
D
(stand back and waits for those in the know to point out the obvious)
Any ideas??
D
