Grating/ clinking noise when revved hard
Posted: Fri Jul 20, 2007 9:12 pm
by dwyryd1
Our Bongo has been making a grating/ clinking noise when it is revved hard, normally when pulling away from junctions/ accelerating:
- appears to be coming from middle to rear near side
- sounds like cross between metal being drawn across a cheese grater and
glass bottles clinking together
- only occurs when accelerating/ revving hard but not when standing still
- can hear the noise clearly inside and outside the Bongo
- our mechanic can not see anything obvious
PLEASE HELP!!
Posted: Fri Jul 20, 2007 9:34 pm
by Seeker
Sounds like a bearing disintergrated!
Jack each wheel up in turn and see if there is anyplay when you try to pull it in and out!
Posted: Fri Jul 20, 2007 9:36 pm
by dwyryd1
Thanks for the reply, but don't think the noise is coming from a wheel and does not get worse when cornering. Might be worth a check though!
Posted: Fri Jul 20, 2007 10:56 pm
by ChrisEm
Have you checked the uj's on your propshafts?
Posted: Fri Jul 20, 2007 10:57 pm
Have you lifted the engine bay covers and had a good listen. Maybe a crude ear trumpet made from a length of garden hose, maybe with a funnel on the end away from your ear, might help locate a source of the noise above the general engine bay cacophony - not practical while driving of course! 8)
Posted: Sun Jul 22, 2007 7:07 pm
by dwyryd1
Thanks for the ideas. Will try them. Any more techies out there?
Posted: Sun Jul 22, 2007 7:24 pm
by dreamwarrioruk
is it only when driving, you say revving but not when standing still.
if its when driving its either wheels, gearbox or rear axle/propshaft. is yours 2 wheel drive or 4.
Posted: Mon Jul 23, 2007 7:58 pm
by dwyryd1
We have 4wd.
Only occurs when pulling away from junctions and accelerating at relatively low speeds (below 30mph).
Posted: Mon Jul 23, 2007 8:02 pm
by westonwarrior
so it occurs when reving hard but only up to 30 mph? when starting off not while crusing, how about breaking?
I am wondering if you have something loose in your tool compartment thats sliding back when you accelerate. probably a silly idea
Posted: Mon Jul 23, 2007 8:14 pm
by dwyryd1
No noise on braking but occassionally when going over pot holes and bumps.
Quite nosy from outside.
Posted: Mon Jul 23, 2007 10:00 pm
by Steve L
Could it be something like a loose baffle in the exhaust?
