I can't actually see the pump because the second battery is in the way. Has anyone got any experience of fixing this problem?
Rear Screen Wash electrical problem
When I twist the stick the rear wiper goes but no water comes out. I have tried this with the bonnet open and there is no motor noise so I guess the motor is duff or there's a bad connection.
I had my washer bottle out yesterday for a different problem.  I have submitted a post on how I got it out.  See 'smelly washer bottle'.
									1995 N reg 2WD AFT in green/grey
www.whiteroseancestry.co.uk
				Tony1966
				Harry
Several solutions/probs spring to mind
1. If you operate the switch and you can hear the washer motor then this would indicate a broken pipe between the washwer moter on the back screen outlet...symtoms+ damp ceiling..water being pumped into ceiling cavity.
2. Operate the switch..nowt comes out if nozzle...dry ceiling = nozzle blocked or pipe disconnected at motor.
3.
No motor sound...motor broke or fuse gone.
Remedy ... check/replace fuse then replace motor (on back of washer bottle.)...any washer pump will do...just tape it into place.
good luck
H
3.
good luck
H
Looks like I have a job to do on Saturday morning. Battery out, battery tray out and tray support out and then I can get to it.
Thanks for your help. I think if its knackered I will fit a standard one from the local car shop.
Pete
Pete
