Fuel Guage Packed in .
Posted: Tue Jul 17, 2007 10:36 am
by Shane
Fuel Guage Has Stopped Working.
I am sure there will be a number of possible causes can anyone
point me in the right direction.
Thanks.
Posted: Tue Jul 17, 2007 10:41 am
by Peg leg Pete
Hi Shane, have you checked the earth wire on the fuel sender, its hidden under the carpet under middle seats, you will see a metal plate undo the screws to reveal the sender, check contacts arre clean and re earth if necessary
Posted: Tue Jul 17, 2007 12:18 pm
by Shane
Thanks Peter. I have just been out in it again and you have guessed
it is back working. It could be as you said I will have a look,
Posted: Tue Jul 17, 2007 5:17 pm
by dreamwarrioruk
a common fault with them.
the connection with the earth is a very small pop rivet which comes loose so you get an intermittant fault then nothing, clean up one of the screws on the plate and crimp a piece of wire between that and the wire nearest to the front of the bongo on the plug connection, that one is the earth providing they havnt changed from a 95 model. i believe the colour is black.
Posted: Fri Jul 20, 2007 12:07 pm
by Shane
Thanks again it is only showing half a tank and I have just filled it to the brim. I will have to have a look when i get time.
Thanks again
Posted: Fri Jul 20, 2007 12:36 pm
gotta be a poor earth surely. Travel in hope & good luck shane.
