Heater fan & Air Con
Posted: Fri Jul 06, 2007 8:33 am
by Nobby
Hope you someone can help! I have just got a Ford Freda 1996 SGL3F
The front heater fan was not working so following the very good instruction from the fact sheets ( thanks to Paul Meeghan ) I fitted a new fan & repaired the resistor. The fan now works on all 4 speeds. The problem is with the air con, it works when the fan is on 1 (in the front & the back) but as soon as I turn it to 2,3 or 4 it stops working in the back completely(fan & air con) with just the fan in the front going (not the air con ).
The small light on the air con switch also goes out
Cheers Nobby [-o<
Posted: Fri Jul 06, 2007 9:47 am
Nobby. Did you 'repair' or replace the resistor? Sounds v odd, like the wiring connections are now incorrect. If replaced resistor, is it the right type for your model? The aircon is clearly working as a piece of machinery. I believe the fan has to be on position 1 or more for it to work. Also - but you know this - there is a master switch on the dash to control the rear unit on/off
I dont really know about this stuff but hopefully someone on BF will have an idea.
Good luck
Mike 8)
Posted: Fri Jul 06, 2007 10:43 am
by Nobby
Mike,
I repaired the resistor simple job, just resoldered the 5 conetions. The old fan had locked up this would have over heated the resistor & melted the solder. The air con had the same problem before I did this & the rear master switch works okay.
Posted: Fri Jul 06, 2007 11:09 am
Hmmm. You sound confident with the work you've done, cant think what else to suggest. Is it worth prodding round with a multimeter to see what current / voltage is where, when switch set to different positions?
Where's the BF Cavalry - you need 'em right now!
Mike 8)
Posted: Sat Jul 07, 2007 6:32 pm
by Nobby
All sorted, I did not do a good job on the soldering, one of the 5 tads came apart. I have now done the job properly and all is well.
thanks Mike for your input
