TOW BAR WIRING
Posted: Thu Jun 21, 2007 5:24 pm
by brianwfl
Hi Kefysher,
re towing iring
12n socket
pin 1 yellow left turn indicator
pin 2 blue fog light
pin 3 white earth
pin 4 green right turn indicator
pin 5 brown right side light
pin 6 red brake lights
pin 7 black left side light and No. plate light
12s Socket (Post 1998)
pin 1 yellow reverse light
pin 2 blue spare
pin 3 white earth
pin 4 green power feed and auxillliary battery charging
pin 5 brown spare
pin 6 red fridge
pin 7 black earth for pin 6
brgds brianwfl
Posted: Thu Jun 21, 2007 6:16 pm
by dreamwarrioruk
look underneath the rear arch of the nearside rear wheel there are two closed grommets that will allow you to push the cables into the rear panel area so that you can get into wire to the rear cluster. note that the colours change in the multi plug from the cluster to the space in the rear panel.well they did on ours.
