Tyre pressures
Posted: Sun Jun 17, 2007 5:23 pm
by Keswick
I've looked and looked in members and all I can find is lots of discussion on sizes of tyre. Really need to pump ours up and need the pressures. Can you tell me what pressures we need fore and aft for normal loads? Cheers.
Posted: Sun Jun 17, 2007 5:24 pm
by Peg leg Pete
32 p.s.i. front 34 p.s.i rear
Posted: Sun Jun 17, 2007 7:57 pm
by francophile1947
I have 205/65s all round and find the recommended pressures too low - I use 34 front and 36 rear.
Posted: Sun Jun 17, 2007 8:00 pm
by Peg leg Pete
My tryes are 195's and I find the pressure fine
not arguing Franco honest
Posted: Sun Jun 17, 2007 8:14 pm
by francophile1947
Didn't think you were Pete - different tyres and different loads make each vehicle different. I used the guide figures to start with, but tyres looked flat and steering was vague, so I upped them and found an immediate improvement. Thing is to experiment, within reason, and keep an eye on the tyre wear, braking effects etc.
Posted: Sun Jun 17, 2007 10:44 pm
Returning to thread, I'm with franco. I put my rears up to 38-40psi when trailer was attached as they looked a bit bulgy. Havent bothered to put them back down and they look and ride v nicely. Am I being very naughty?
Mike
Posted: Sun Jun 17, 2007 11:41 pm
by trevd01
The manual says 2.0 bar front (29 psi), 2.4 bar rear (35 psi).
I run ours (215s all round) at 34 front and 38 rear. I feel happier with the ride and handling at slightly higher pressures.
Posted: Mon Jun 18, 2007 3:30 pm
by smartmonkey
I run mine a bit high as well, 40 back and 38 front. I find it drives a bit crisper and turns in nicer. 34 is very low for the weight and I didn't like the bulges. My tyres are rated for 50psi so well within tyre specs.
Posted: Mon Jun 18, 2007 3:56 pm
by vic swan
195s allround, after much experimenting I now put in 40 allround. Suits me and handles fine.
