Speedo stuck at maximum...
Posted: Fri May 25, 2007 12:53 pm
It's always worked fine before, but now it's stuck all the way round to the right, against the pin. Doesn't move at all, even with ignition off. Gear shifts are working fine.
When I bought it (three weeks ago) it had already been chipped to MPH and had new faceplate. Had intermittent problem with the hold light flashing, which other posters have linked to the speedo chip - that's never been a problem though, as it's fixed by restarting.
I did several searches but couldn't find anyone with the same problem. I've had a quick look for the speedo cable underneath without success, but surely if that had come loose the speedo needle would be stuck on the left? Bit stumped.
On balance the Bongo's doing well; got the air-con working (think maybe it was drained when imported) and it drives beautifully. Very pleased
