A wiring question and a beeping question
Posted: Fri May 25, 2007 11:05 am
Hi all,
Just joined up, having only had my 97 Bongo for 4 weeks, great to be on board and browsing this forum I am impressed at the helpfullness of everyone.
Hope someone can help with a couple of questions I have which I have not managed to find an answer to by searching the forum:
Question 1:
At the week-end I want to put some electrics in my bongo. I have a rear kitchen unit with the water pump running off the existing rear socket, but I don't want to attach too much else to that as I suspect it's not man enough - and besides, it only comes on with the ignition fully on.
What I want to do is run a new cable from my leisure battery to a surface mounted 12v socket which I will mount behind the kitchen unit.
Into that socket I want to plug a 3 x 12v socket adaptor (So I can unplug and take the kitchen unit out leaving all the electrics attached to the unit, and just the socket in place).
Into the adaptor I want to put the water pump (so it works without the ignition on), a cable to a 12v socket mounted into the side of the kitchen unit, and a 150w inverter which I will mount behind the kitchen unit, and then take a cable to a 240v 3 pin socket also mounted on the side of the kitchen unit.
With me so far ?
The 240v socket will just be used to run a portable TV/DVD, Laptop etc - nothing more powerful.
The 12v socket will be there, erm, in case I need it. I know, to charge my mobile phone up
Somewhere in the cable leading to the new surface mounted 12v socket I will put a switch so I can isolate the power to the back of the van (but keep the original 12v socket on the ignition switch as a 'spare').
After all that, the question is simple - what size of cable should I run from the leisure battery to my new surface mounted socket?
Some folk I speak to say 8 amps is enough, others say I need at least 25 amp because of the distance the cable is going. So i'm confused.
Is it best to just fit the biggest I can get ?
Also, can anyone see any fatal flaws in what I plan to do
Question 2:
How easy is it to disable the bleep bleep bleep which drives me mad when I have the key in the ignition but the ignition off and the front door(s) open while working on the Bongo ?
Last week-end I fitted a new stereo and dash clock and it was bloomin' hot. I wanted the key left in so I could easily put the ignition on and off as I checked my wiring, but the bleeping was driving me mad, so I had to shut the doors. And I got very hot.
Can this 'safety' feature be disabled ???
That's it. Do I get some kind of prize (or derision) for posting the longest first post
Question 1:
With me so far ?
Question 2:
