Couple of questions for the sparkys!
Posted: Wed May 23, 2007 3:34 pm
I am in the process of fitting a leisure battery with the invaluable information all over the site courtesy of corblimey, Pippin and alpha (amongst others - thanks all). I now have a couple of other questions which I would be very grateful for a second (or third, etc) opinion on.
Question 1
I have a Kenwood stereo with the usual permanent live connection and a switched accessory feed to allow it to switch on and off. I can connect the permanent to the leisure battery no problem, but I don't want to connect the acc feed permanently - I would like to keep it switched from the ignition. BUT, in addition, when not running off the ignition (i.e. camping), I would like to be able to turn the radio on/off from the back using a separate switch.
My idea was to wire a switch in parallel to the accessory feed (an OR switch if my memory of logic circuits is correct). The problem I saw was that the acc feed is from the main battery ,and the permanent from the leisure so to keep them isolated from each other, I was thinking of introducing a relay to the party. So, the ignition feed (or switch wired in parallel) would trigger the relay which would switch a direct feed from the leisure battery giving the radio it's 'on' power.
Does that make sense/sound right? Would it work? Have I missed anything or am I barking up the wrong tree altogether?
Question 2
I have installed a couple of additional lights to the interior that I would like to come on when the interior lights do, and then also be able to switch them independently from a switch in the back. I was thinking a parallel arrangement again but I'm not sure where to take the feed from. The lights will be routed from the leisure battery at the fuse box so no worries about relays this time round.
Would be very grateful of anyone's suggestions on this. It's a while since I've dabbled with anything electrical and I'd really like a 2nd (3rd, 4th...) opinion!
Many thanks,
Andy
Question 1
Question 2
Many thanks,
Andy
