brake noise
Posted: Mon May 21, 2007 5:33 pm
by littlewoods
i have just fitted new disc's and pads to the rear brakes all fine ...but am getting this binding/grinding metal on metal type noise now and then. i have been informed that there maybe brake shoes inside the rear drums which could be the problem its something to do with the hand brake etc. has anyone come across this before and if so were do you get the shoes from any ideas....cheers
i have a 97 bongo
re brakes
Posted: Mon May 21, 2007 7:37 pm
by redalan1971
brake squeal may be the cause and can be caused if the anti-rattle shims are not fitted or incorrectly fitted.
as the the rear drums i have a 95 bongo and its discs on all four corners so no drums.
Posted: Mon May 21, 2007 7:40 pm
by etihsbog
I thought there was a set of shoes inside the rear disc to act as parking brake and pads to stop the vehicle, in effect it is a drum with a disc welded to it. Might be wrong but it is worth a check redalan.
Re: re brakes
Posted: Mon May 21, 2007 7:43 pm
by littlewoods
redalan1971 wrote:brake squeal may be the cause and can be caused if the anti-rattle shims are not fitted or incorrectly fitted.
also what i noticed is that when you lift the handbrake up slightly the noise goes away its a strange one. i also have all round disc....but the shimms is one ive not heard about..cheers
Posted: Mon May 21, 2007 7:47 pm
by Veg_Ian
Brake drums are inside the rear disc for the parking brake. May just need bedding in, edge of the pad could be catching. Did you apply a smear of grease to the shims and pads?
