it must be simple but....
Posted: Wed May 16, 2007 12:23 pm
by skater
hi , just got our bongo the other week and want to swap the space saver tyre for a normal one.
have joined the club and browsed the forum.
found plenty of discussion about how useless the space saver is
but how do you remove it?
can't be that difficult can it?
cheers from devon
Posted: Wed May 16, 2007 12:46 pm
by Peg leg Pete
You need to use the tools located in the compartment under the side door, Long tube section locates in hole at rear of vehicle when back door is open, use ratchet to unwind the wheel.
Posted: Wed May 16, 2007 12:59 pm
by skater
thanks for the reply.
i fond that hole at the back and assumed you did something like you said
but apparently i dont have the required tube in the toolkit!
any ideas?
will go out now and frown at it for a while, that should help.
Posted: Wed May 16, 2007 1:06 pm
by Ian
If you need to buy one of the removal tools, we stock them in the club shop.
Wheel removal tools
Posted: Wed May 16, 2007 4:13 pm
by Vanmanerik
Where you found the jack, in the cubby hole of the sliding door step, feel along the top and you will find a metal rod avout 30cm, 2 ft, long :D
Poke this in the slotted hole below the rear door, turn it around a bit and the spare wheel will be lowered to the ground.
Hope this helps.
Posted: Wed May 16, 2007 7:24 pm
by James and Mair
thanks vanmanerik, i did exactly that earlier and lo and behold there it was.
i hadn't spotted it 'til i got right down and looked ( and had an idea what to look for ).
thanks to all of you.
nice to have friendly help out there.
Posted: Wed May 16, 2007 7:30 pm
by James and Mair
oh yeah, just noticed.
sometimes i appear as " skater "
sometimes as " james and mair"
depends if i'm logged on or my wife.
ha ha
