removing radio.......sorry!
Posted: Wed May 09, 2007 6:55 pm
by spitineye
sorry for such a tedious waste of your eyes and resources but i still can't get the bugger out! when fitting my new stereo a few months ago, despite EVERYTHING i've read here on it's removal, it won't budge. i had my glove compartment out, head inside the dash, looking right at the damn thing, yet, there he sits. mocking me.
i successfully removed the sat nav, and fitted it in his place so it's not an urgent matter. it just looks a bit odd, be it a bit flash, with my separates hi-fi system ...
Posted: Wed May 09, 2007 7:06 pm
by pippin
Have you removed the two plastic bits at the sides?
They just clip out using your fingernails.
Then you need the two round metal U-shaped prongs that fit one either side into the two holes either side.
The ends of the prongs depress the locking tabs inside, the grooves near the ends of the prongs grip the springy tabs to help you remove the radio.
Posted: Wed May 09, 2007 8:05 pm
by trevd01
Depends on the make. Many have a 'two holes' release mechanism, which a suitable piece of wire coat hanger will deal with. Other type have different shape tools. You can buy them all in Halfords.
or look here:
http://tinyurl.com/2n8qve
Posted: Wed May 09, 2007 8:25 pm
by waycar8
have you put your hand at the back of the stereoto feel for a nut?.................some are held in place by a nut
Posted: Wed May 09, 2007 8:32 pm
by spitineye
yep, tried the (makeshift) hooky-dealys. although the wire may have been a bit flimsy. i'll make some new ones from welding rods. oh yeh, i forgot i failed my recent welding test
so im not allowed to weld again until i decide if i want to resit. balls to them! well, what do they expect if the only time i weld is when i'm sitting my tests! (every year for gas, 3 years for metal arc)
um, where was i.
Posted: Wed May 09, 2007 9:37 pm
by swifty
Is it a Japanese radio cassette with prog buttons top right and lcd screen below cassette opening? If so I have one in my hand and can send pics of side which shows clips. I reached them through the side, its a two finger press if you'll excuse the term!
Better let me have an e mail address if you need to see, radio removal yes, posting pics well not yet!
Posted: Wed May 09, 2007 10:58 pm
by swifty
When I say the side I meant the removed glove compartment opening.
You can see how the progny wires work but I didn't need them, just reached in and pressed
Stereo retractors
Posted: Fri May 18, 2007 8:40 pm
by johnzbenson
Small Allen keys (the ball ended type) can double as one kind of retractor- better than just welding rods as the radius of the end tends to fit just inside the recess for the proprietry items.- some radio cassetes are fastened by a piece of thin flat bar from the center earting point (4 or 5 mm bolt coming out of the centre at the back of the radio unit)
I hope this helps. if not, if you have a digital photo of the setup you could put on here... I'm sure someone could advise from this.
wave extender on jap radio
Posted: Fri May 25, 2007 9:32 pm
by bluekingfisher2
hi anyone fitted a wave band extender to the bongo radio so you can get better fm coveriage many thanks graham
Posted: Fri May 25, 2007 9:36 pm
by NeilT
bluekingfisher2, I understand that they really are not that great.... best to fit a new unit... dead simple and quick to do
Posted: Fri May 25, 2007 9:38 pm
by maxheadroom
Hi bluekingfisher2
Don’t bother with the wave band expander when you can buy a stereo for the cheap.
Cheaper than the expander.
http://www.maplin.co.uk/Module.aspx?Mod ... 1&doy=25m5
