Page 1 of 2
Inset fog light + Inset reversing light option
Posted: Fri Mar 23, 2007 12:50 am
by vanvliet
A while ago some folk commented that having one fog on the RHS annoyed them because having one light looked odd on the bumper. Some fitted twin fogs but an alternative might be to fit an extra reversing light . It uses the same frame as the fog.
http://i109.photobucket.com/albums/n54/ ... P02310.jpg
Posted: Fri Mar 23, 2007 1:14 am
by Simon Jones
Any idea where to get the plain type from? I have the red equivalent already.
Posted: Fri Mar 23, 2007 1:16 am
I think it was bigdaddy who was v interested in this (I know someone was) but didnt know where to source clear lens covers. V interesting if you've found a source vanvliet
Posted: Fri Mar 23, 2007 9:18 am
by pippin
Me too.
Posted: Fri Mar 23, 2007 10:57 am
by maxheadroom
Found these on ebay.com,
They are in the good old USA and they will ship to the UK
Total cost £14.76p
http://cgi.ebay.com/ebaymotors/ws/eBayI ... ingPayment
Posted: Fri Mar 23, 2007 11:51 am
Smart man Max - well done! I'm going to look like a bit of a square if these catch on
Posted: Fri Mar 23, 2007 1:18 pm
by vanvliet
Sounds like the USA source might be a good deal cos Protechnical are selling them for £23 plus vat . Seems that the fog lights are cheaper because they sell a lot more of them and get bulk order discounts.
The light is made by hella .There may well be other sources of supply .
PROTECHNICAL LTD
23 Clevedon Road, Nailsea, Bristol. BS48 1EW.
Tel : 01275 859955
Posted: Fri Mar 23, 2007 1:21 pm
by vanvliet
Just looked at the USA link above - - - It is a totally different light /housing . So its the Protechnical price to beat if you want to match the rectangular fog
Posted: Fri Mar 23, 2007 1:47 pm
'fraid so. I still think a very intersting approach would be a lamp that shines into the reversing mirror (or at least downwards from it), which then spreads a pool of light over the area of most importance when reversing. But then my name IS
Heath Robinson.
Posted: Fri Mar 23, 2007 5:15 pm
by David Edwards
They do look so much smarter set into the rear bumper, it's whether I have the guts or not to attempt to cut the holes is the question for me. I still have a voice warning reversing gizmo to fit as well, simple to do it's just doing it, that's the problem. Happy motoring.
Posted: Fri Mar 23, 2007 5:27 pm
by Ozric
I was the same as you David. I had the light for weeks before I had the guts to cut the hole. But I'm very pleased with the results.
I wouldn't bother with an extra reversing lamp, having tinted windows it would only make it slightly less dim.
Posted: Fri Mar 23, 2007 5:36 pm
Agree with Ozric on all counts. the trick with the hole cutting business is measure once, measure twice, mark out with masking tape, all of this 60 times if need be but just take your time. The plastic cuts beautifully though (just drill a little hole in each corner of the cutout area at start of job and check after each hole that it is coming out on the blind side where it should - then drill a few more small holes along a side and join them up using side pressure on the drill - then you can get a coping saw blade in to rrun along and cut out that side).
Mike
Posted: Fri Mar 23, 2007 6:38 pm
by David Edwards
Daft question now, are the rear fogs a standard buy or from evil bay, I am thinking about sizes to cut. Happy motoring.
Posted: Fri Mar 23, 2007 6:59 pm
by vanvliet
Hi Dave
I bought mine from here
http://www.importedvehicles.co.uk/fog_lights.htm
Specify the nice round switch - it comes as part of the kit and if you already have a Mazda dash one it can be used for other electrical stuff
The frame is really easy to fit You can even colour code it to the bumper if you want .
Posted: Fri Mar 23, 2007 7:55 pm
by Peg leg Pete
The Foglight is a Ring brand, sure they have a factory in Leeds
