Waeco MS 50 Cruise Control - Fitting
Moderator: Ian
Re: Waeco MS 50 Cruise Control - Fitting
Post by Bob » Sun Jul 16, 2017 6:37 pm
Hi Sam, and welcome. 8)
There was a 'Fact Sheet' in the Member's area, not sure if it's still there.
I'm sure Simon Jones did it so worth a PM if you can't find it, but they are a fairly straight forward fit. :)
mitchelln
Post by mitchelln » Mon Jul 17, 2017 2:01 pm
I've just bought a MS50 as well, but I can't see a fact sheet in the Member's area. I've dropped Simon a PM :)
Black Aero City Runner 2L petrol with full side conversion
cmm303
Post by cmm303 » Mon Jul 17, 2017 4:46 pm
I have a copy of the installation instructions that Simon emailed me in the mists of time. If you PM your email address I will forward it on.
It really helps with getting the sensitivity things right first time.
Chris with BertieB
Post by Bob » Mon Jul 17, 2017 8:07 pm
And from memory you need to connect to a blue/white behind the speedo.
There are two, but now you know that it's obvious which is the right one. :wink:
cmm303
Post by cmm303 » Tue Jul 18, 2017 9:01 am
Bob wrote:And from memory you need to connect to a blue/white behind the speedo.
That's a good memory Bob, all the way back to 2014 :lol: . My dilemma with two blue/white wires coming of the instrumentation connectors. And for our current readers .... its the one off the wider (middle) connector. It should trace back to SP+ on the circuit board.
Little deviation - reading my post back then referencing "the gubbins mounted on the chassis under the passenger seat" is a little embarrassing. :oops: It really demonstrates the patience shown by those far more experienced when helping the inexperienced with stuff that would have seemed so obvious. This is a real strength of this forum. =D> \:D/
Chris with BertieB
Post by Bob » Tue Jul 18, 2017 9:53 am
Indeed. =D>
My 'Gubbins' is under the driver's seat, the cable to the throttle went in a nice wide 180 degree curve to the mounting point. :)
I used an existing bolt which holds the carpet clip thingy.
cmm303
Post by cmm303 » Tue Jul 18, 2017 10:16 am
The "gubbins" I had queried turned out to be the quick warm up exhaust valve control system but I hadn't a scooby. All I knew was it was using the vacuum take-off that the fact sheet points to.
Chris with BertieB
Post by Bob » Tue Jul 18, 2017 11:19 am
Sorry, differnt gubbins.
Don't mean to confuse. :oops:
Bathildabongo
Post by Bathildabongo » Fri Jul 28, 2017 7:18 am
Thanks for the warm welcome, and sorry for the late reply.
I have sent Simon a PM but yet to hear back from him. Summer holidays may have kicked in and he's enjoying the sun. cmm303 I have sent you a PM. If you get the time can you send over the plans, please? I am heading out tomorrow to get this fitted and running.
Many thanks.
janandhamish
Post by janandhamish » Fri Jul 28, 2017 11:09 am
Thanks to cmm903 for the pdf .All ordered from Conrad for the princely sum £131.98 inc postage.Arriving Monday and then all things being equal I'll fit it Tuesday.
Only thing I'm dithering about is where to mount the controller.......
Post by Bob » Fri Jul 28, 2017 12:37 pm
I put the buttons down by my left knee.
Others have fitted them near the gear selector but you need to unplug before removing the trim to raise the seats.
You may well remember but it's bound to go to a garage sometime. :wink:
janandhamish
Post by janandhamish » Wed Aug 02, 2017 4:20 pm
Well all fitted and working straight out the box.Many thanks to all who supplied the know how PDF etc.
Briefly it took 4hrs start to finish but that included messing about making an insert for the dash and I didn't use any scotchloks (can't stand the things) also made up a small loom for the brake light switch as I felt the OE wires were too short to tap into.
The controller I mounted where the heated rear window switch was and have moved that down to one of the blanks below,all falls naturally to hand.
So again many thanks.
Hamish
Post by Bob » Wed Aug 02, 2017 4:54 pm
Splendid, and thanks for the update. :D
Bathildabongo
Post by Bathildabongo » Wed Dec 06, 2017 9:10 pm
sorry for the delayed message.
Mine is all fitted and working swimmingly, thanks to the great guide. I have passed the control so it feeds out between the ashtray and gearstick. Looks great and very handy position to control the speed in traffic without taking my arm off the rest. Again, sorry for the delayed response. I very much appreciate all the help I received here and will hopefully become a more regular visitor and poster. I think I will be fitting one to my brothers van in the next couple of months and I’m sure the instructions will again come in handy.
Post by Bob » Wed Dec 06, 2017 9:14 pm
Well done, and thanks for the update. =D>
Return to “Pimp My Bongo”
