Re: overheat while stationary, thermostat?
Posted: Fri Jan 09, 2009 11:00 pm
Lovely pics there Simon. Phew - makes you realise what a fancy piece of casting it all is
A forum for Bongo fans and owners
https://igmaynard.co.uk/bongo/forum/
Yup, I noticed that and thought of you. Still trying to get my head around it though as if it is flat, how do you grind/skim/machine anything off it without making valve seats more shallow, plus with the valves ending up 'lowered' into the bores as a result (and that in turn decreases internal volume of combustion chambers thus raising compression ratio). Once I can get my head around all that then I'll understand why g/s/m'ing a flat head makes no diffrence to compression ratiodandywarhol wrote:So it defintely is a flat faced head - previous comments made about skimming not affecting the compression ratio still stand
Because it's an "indirect injection" diesel there is also the volume of the pre-combustion chamber in the head (where the injector nozzle and glow plug are) it's behind the circular plate with an oval opening in it.Trouble at t'Mill wrote:Jeepers, are these the pistons flush with the top in the second picture?
Are the 'combustion chambers' just these little recesses in the pistons?!!
I know that diesels have high compression ratios, but I never realised it was like this...
As scanner says, the precombustion chamber takes some of the compression volume. These cutouts on the piston crowns are more valve recesses - there's probably no more than about 0.5mm clearance to allow for conrod "stretch" at high revs and some overlap at TDC. The Bongo engine will be running around 20/22 :1 compression ratio I guess - around 430 PSI of pressure.mikeonb4c wrote:Yup, I noticed that and thought of you. Still trying to get my head around it though as if it is flat, how do you grind/skim/machine anything off it without making valve seats more shallow, plus with the valves ending up 'lowered' into the bores as a result (and that in turn decreases internal volume of combustion chambers thus raising compression ratio). Once I can get my head around all that then I'll understand why g/s/m'ing a flat head makes no diffrence to compression ratiodandywarhol wrote:So it defintely is a flat faced head - previous comments made about skimming not affecting the compression ratio still stand
