Battery tester for leisure battery.
Re: Battery tester for leisure battery.
I've seen how fast you drive carl....You'll be there before you set off!
I got around to testing my 4 lead voltage display jobbie today, connected the power supply & measurement leads together, worked fine, might get around to fitting it at some point
Got my eye on sticking it in the silly little cubby hole to the right of the steering wheel, maybe, I want it switchable between the 2 batteries on a push to make basis.
Going to have to go over my round tuit list for the new year
I'm super duper pleased with the result I got with mine by using the space of 3 switch blanks (after removing the vertical internal dividers) and using a piece of mousemat neoprene tuype rubber as a gasket. Depends if yours is the right size to fit but when I researche these things they seemed to be in two different sizes, one of which was perfect.missfixit70 wrote:I got around to testing my 4 lead voltage display jobbie today, connected the power supply & measurement leads together, worked fine, might get around to fitting it at some pointGot my eye on sticking it in the silly little cubby hole to the right of the steering wheel, maybe, I want it switchable between the 2 batteries on a push to make basis.
...apologies for poor focus
Most of my switches are being used or have things already planned for them
Looks like it's a pretty good fit in the cubby, unless I come up with a silly idea in the meantime
I shoulda guessed. You girls and your gadgets (said the pot to the kettle)missfixit70 wrote:Most of my switches are being used or have things already planned for themLooks like it's a pretty good fit in the cubby, unless I come up with a silly idea in the meantime
This is the one I've got if anyone wants one http://cgi.ebay.co.uk/20Vdc-Green-LED-D ... 240%3A1318
missfixit70 wrote:This is the one I've got if anyone wants one http://cgi.ebay.co.uk/20Vdc-Green-LED-D ... 240%3A1318
Well dang me dang me they oughta take a rope an hang me, I think that's the same one I got and from the same supplier. What with that and our identical wheels, peeps will be starting to talk Kirsty
- Tribal Elder
thinking aboot getting a meter and fitting it into the space where the 3 switch plates are, but my front fog light switch is there will i be able to site it anywhere else?
cheers.
99 new shape 2tone silver 2wd aft
cheers.
Depending on the slack on the cables, it should go over to the switch bank on the other side...Easy enough to extend the cables a little i'd have thought...
Is it an original mazda switch, or an aftermarket item?
- Tribal Elder
more than likely the same meter as missfixit70,seems the best and the right color.
Or put the meter on t'other side, or in the little cubby hole to the right of the steering wheel.
